Transmission lag
Wordski
Year and Trim: 2004 Pontaic Bonneville SE
Transmission lag
Post by Wordski »
I just bought an 04 with 99,000 miles on it.I noticed when shifting it into drive,it takes a split second longer to change gears than any other car Ive driven.If I do it the way I normally would I end up jerking the transmission which I know isnt good.Is this just the way these cars shift or is it an actual problem,the only thing I can think of is maybe a dirty valve body.
Re: Transmission lag
Try running some seafoam transtune for a hundred miles or so, then drop the pan and do a fluid and filter change.
RookieSSei
Year and Trim: 2002 SSEI
ALL STOCK (FOR noW)
Post by RookieSSei »
well.. it s been a while but yea try some trans tune that might work i just had alot of trans issue fixed now but thats not normal i dont even feel my shifts at all
Wordski
Post by Wordski »
Sorry,I didnt mean 1-2,2-3,etc. shifts,I meant it took a split second longer to shift into drive.
golfyeti
Every available option
Post by golfyeti »
That split second delay might be a symptom of a bad front trans/motor mount -- a very common failiure on 2000+ Bonnevilles.
Mark
The Familyman's Trans-Am
Intense 3.4 MPS, Intense FWI, Intense PCM, copper NGKs TR55's, MSD wires, MSD coils, BWD ICM, MagnaFlow High Flow Cat, drilled 180 'stat, solid front mount, Monroe Max Air rear shocks, Moog rear mounts, Moog suspension bushings, cleared front corners, 190,000 miles
wjcollier07
Year and Trim: ____
Post by wjcollier07 »
or it could simply be a sticky solenoid with a nice varnish buildup that could be taken care of by the seafoam trans tune.
highly recommend the stuff..i've used it to resurrect aging, rough, and delayed shifting transmissions with great results.
as Ed mentioned, 100 miles or so and then drop the pan, drain, and change the filter...hopefully it'll start working you towards the solution you're looking for.
John
Wordski
Post by Wordski »
Thanks guys,will try
Wordski
Post by Wordski »
BTW,where can I get the trans tune from?Any national chains carry it,or is it an internet thing?
1fatcat
Year and Trim: before cars
Post by 1fatcat »
Does it do it every time or only on first start up of the day?
Wordski
Post by Wordski »
everytime,im thinking it might be the mount because I can feel it pretty good through the car when it goes into gear,especially reverse
Archon
Post by Archon »
Attend the Michigan meet, and we can check things over for you. Barring that, I could probably meet up with you somewhere to check things out.
You can get trans-tune at just about any parts store across the nation.
