Missing Antifreeze
wjcollier07
- Year and Trim: ____
Re: Missing Antifreeze
And of course the installation instructions, also covering your question about the old stovepipe.
http://www.ineedparts.com/product-info- ... 17806.html
John
- grandprix104
- Year and Trim: 2001 SE L36
Ok, as long as you are aware that this is a temporary fix (I would GUESS in the 2-3 year range). On first inspection my old UIM, or Plenum by another name, is in good used condition. I did not see any cracking or deterioration in the coolant port/egr area. I mentioned I purchased an APN kit for my repair. It turns out only my LIM gaskets were leaking, not the UIM/gaskets. I installed the kit as I had already paid for it. It came with both a 3/4" stovepipe, and a 5/8" stovepipe. I used agrazelas ported LIM (an older model with the 3/4" fitting). This leaves me with a 5/8" stovepipe that will fit a newer style LIM like yours. What the smaller stovepipe accomplished in the old style kit is create more space between the hot EGR stovepipe and the plastic crap GM used for an intake manifold. In the APN kit they add another metal bushing that helps protect the plastic like a heat shield. It is pictured on the APN website above. By using my old UIM and the smaller 5/8" pipe you get more airspace between the metal and plastic, and thus, less of a chance that the UIM will crack and deteriorate. It will probably deteriorate eventually but this will buy some time. I will try to get a pic of how it will look on your setup. I will check my UIM really well to make sure it is in reusable condition. I will post back tomarrow and let you know if it is ok and what shipping would be.
- JBMark33
- Posts like an L36
- Year and Trim: 2000 SE
Okay, I understand the chances. Is there any place I can order the reduced diameter stovepipe individually?grandprix104 wrote:Ok, as long as you are aware that this is a temporary fix (I would GUESS in the 2-3 year range). On first inspection my old UIM, or Plenum by another name, is in good used condition. I did not see any cracking or deterioration in the coolant port/egr area. I mentioned I purchased an APN kit for my repair. It turns out only my LIM gaskets were leaking, not the UIM/gaskets. I installed the kit as I had already paid for it. It came with both a 3/4" stovepipe, and a 5/8" stovepipe. I used agrazelas ported LIM (an older model with the 3/4" fitting). This leaves me with a 5/8" stovepipe that will fit a newer style LIM like yours. What the smaller stovepipe accomplished in the old style kit is create more space between the hot EGR stovepipe and the plastic crap GM used for an intake manifold. In the APN kit they add another metal bushing that helps protect the plastic like a heat shield. It is pictured on the APN website above. By using my old UIM and the smaller 5/8" pipe you get more airspace between the metal and plastic, and thus, less of a chance that the UIM will crack and deteriorate. It will probably deteriorate eventually but this will buy some time. I will try to get a pic of how it will look on your setup. I will check my UIM really well to make sure it is in reusable condition. I will post back tomarrow and let you know if it is ok and what shipping would be.
Current: '12 Audi S4 Quattro Prestige 6MT
Previous: '06 Audi S4 Quattro 6MT (for sale!)
'06 Chevy Cobalt SS, Stage II: 2.0L Supercharged, 16psi boost, G85 Package; Recaro Racing Seats, Limited Slip Differential, 5 Speed Manual
'00 Pontiac Bonneville SE ( 4 years, 197,000 miles)
'99 Dodge Intrepid ES (1 year, 2 engines)
'95 Chevy Lumina (2 years, 164,000 miles)
- grandprix104
I'll GIVE you one
Ok here's what I've got. I cleaned things up a bit and the manifold looks perfect to me. There is NO deterioration around any of the coolant ports or the egr. If I had known it was in this condition I never would have purchased the APN for myself. Here are some pictures: http://s617.photobucket.com/albums/tt26 ... OR%20SALE/
Comes with everything here, and my old vacuum fitting: (I am selling the lower manifold seperately, of course)
The difference between the stock and APN stovepipe in a OEM UIM: This pipe will sit lower when installed in your manifold.
Stock:
APN Stovepipe:
Sorry about the fuzzy pictures, my camera is terrible at close-ups. I will find out shipping here sortly.
Stock:
APN Stovepipe:
- JBMark33
- Posts like an L36
YOU are the man!!grandprix104 wrote:I'll GIVE you one
PM Sent.
- grandprix104
Kep in mind, those injector o-rings probably won't fit, but I've got three sets that size now, and if they work for you, at least one set will get used. Also you could probably find a piece of steel pipe for a "bushing" and just cut it to fit and epoxy it in place. You would then have the equivalent of an APN kit.
- JBMark33
- Posts like an L36
Okay, I am starting to get a little nervous because I can't find anything wrong with my UIM.
Please tell me that you see something on it that looks bad.
Edit -- I just found the issue and the drill bit I found the hole with was 1/16th of an inch thick. Wow. To think something with such a small diameter could almost cause such engine failure.
http://s201.photobucket.com/albums/aa21 ... C02789.jpg
http://s201.photobucket.com/albums/aa21 ... C02790.jpg
http://s201.photobucket.com/albums/aa21 ... C02794.jpg
- grandprix104
ouch! Ya, i think that could do it!
- JBMark33
- Posts like an L36
I am sooo happy I found that hole. You have no idea lol.
Definitely UIM failure, lol.
- JBMark33
- Posts like an L36
Good Call from last week bro!!00Beast wrote:Definitely UIM failure, lol.
Well, since you had the issues and hadn't replaced the UIM, but had replaced the LIM gaskets, so it wasn't hard to figure out.
- grandprix104
So did ya get it all back together yet?? I know it hasn't been long since you picked up the UIM, but just wonderin' how it all turned out.
- JBMark33
- Posts like an L36
Yeah, UPS was unable to deliver it Thurs. due to gusts of wind in Erie, but I picked up earlier today and got it running. At first I had an issue with getting it started since it hydro-locked a second time. I ended up pulling the plugs five times and turning the engine over with a socket and ratchet, but all said and done, it runs like a charm. I drove it 3 hours to see my girlfriend for valentine's day and it hasn't failed me yet. It is running on champion plugs temporarily, but it still seemed to get pretty good mileage on the highway. The install was pretty easy.
Thanks for the UIM!!
- grandprix104
Well, I'm glad it worked out then! Hopefully it last a good while this time
- agrazela
- Retired Gearhead
- Year and Trim: 04 Lesabre, Stock
98 Lesabre, Retired - Location: San Diego, CA
With all the coolant you've ingested, I'd advise changing the oil one or two more times in the next few hundred miles, to be safe(r).
Bone Stock
Retired
Bone Stock
Retired
- JBMark33
- Posts like an L36
First time it hydrolocked last Tues. I got it running that night and changed the oil. The next day, when it hydrolocked again, I had to order in my UIM. I fixed it all yesterday let it run for over 2 hours and then changed my oil and drove it 170 miles. So. yeah I will keep an eye on my oil pressure and probably change it soon again, but It was changed twice in the past week.
I'd change it in about 100 miles, and then go back to your normal interval.
- JBMark33
- Posts like an L36
I have a 180 mile trip home tonight, and then I will take it to school tomorrow, but tomorrow night I am going to put in my brand new Iridium plugs and change the oil one more time.
Sounds like a good plan to me. Glad it didn't result in anything serious.
