Start.
Sadden
1994 Bonneville SSEI
2006 Grand Prix GXP
Start.
Post by Sadden »
How hard is it to add a start button for these cars.
One that would still require the key.
06 Grand Prix GXP Diablosport Trinity , No DOD , Transgo SK , MSD 8.5MM Wires , NGK TR6IX plugs , LED's , Optima RedTop , Projector Retro , 3K Fogs , 20" Led Driving light , K&N CAI w/ Volant oversize air filter , Raybestos Brakes
94 SSEi NGK Plugs , Blue Streak Wires , Pulled Maf screen , Custom Exhaust , Raybestos Brakes , 12" MTX Audio sub and amp , Piaa Plasma Ion Foglight Housings , HIR His' and Lows' , Tinted Tails
lewis26
Year and Trim: 2003 SLE || 51k miles
Re: Start.
Post by lewis26 »
You would probably have to tap into the contacts in the key cylinder for the start portion of it.
Doesn't make much sense to have to put the key in, turn it to on, and then press a button to start it. Maybe if you found a way to add the proximity sensor from another car so you could leave the keys in your pocket.
I really don't think its possible, or that the end justifies the means or cost though.
-Mike
J Wikoff
Year and Trim: 1992 SSE
Re: Start.
Post by J Wikoff »
BonneMe did it on his 93.
willwren
Re: Start.
Post by willwren »
Didn't Jason run his off one of the console switch pod buttons?
J Wikoff
Re: Start.
Post by J Wikoff »
He put a new button on the dash bezel.
Re: Start.
The first time he used the TC button, but it couldn't handle the load so he put in a bigger switch I think.
Bonnememn wrote:I think it's fried... The circuit is good, and all the wiring seems to be in order. It's been used 3x on that circuit, off of a 15amp fuse, into a 10amp fuse to start it.
Today i hit it, and nothing, smell something funny, see smoke from the button, the safety light dies, and a fuse blows.
How much current can a TC button take? :?
Sadden
2006 Grand Prix GXP
Re: Start.
Post by Sadden »
Its just a "Cool" feature IMO.
Nothing beats that big Red Start Button :hal
Re: Start.
Sadden wrote:Its just a "Cool" feature IMO.
:rice: :brice:
wjcollier07
Year and Trim: ____
Re: Start.
Post by wjcollier07 »
Couldn't one of the pod buttons still be used, but just to trigger a relay, using only that very insignificant current?
John
lewis26
Re: Start.
Post by lewis26 »
The only way I could see it being cool is if you add the proximity stuff so the key stays in your pocket.
Otherwise, I agree with Ed, that its very rice if you put in the key, turn it to on, and then reach for a separate button to start it.
-Mike
Re: Start.
Don't wow them with show, wow them with go. :wink: :beerchug:
rharper
Year and Trim: 1999 se
Re: Start.
Post by rharper »
you can do this with a old style horn button ,or doorbell button modifed . have done this on regal when ign was bad, and i was poor. drop starter and run hot wire from starter to switch and ground from starter. just bascially crossing starter . work,s :bhuh: laugh now but works
Sadden
2006 Grand Prix GXP
Re: Start.
Post by Sadden »
Not Rice IMO..
Even with the gen II M62 the car scoots along quite nicely.
And lays rubber well...
I'm sure we can almost all relate to that.
Lots of performance oriented plans.
But the start button is just what seems like a cool easy mod.
Ill just do it with dad..
J Wikoff
Re: Start.
Post by J Wikoff »
I think it's kinda cool.
lewis26
Re: Start.
Post by lewis26 »
I think it has the potential to be cool, but only if you remove the necessity to insert the key.
If you have to insert the key, turn it to on, then reach to a different button to start the car, it seems counterproductive, and IMO VERY rice.
Now, if you can figure out a key proximity set up where you can leave the key in your pocket and start the car, that would be cool.
-Mike
Re: Start.
Post by gonzo4191 »
00Beast wrote:Don't wow them with show, wow them with go. :wink: :beerchug:
or wow them with hundreds of unwanted annoying posts
lowrider0308
Year and Trim: 2006 Chevy Silverado LT
1989 Camaro RS LT1
Re: Start.
Post by lowrider0308 »
Ed :flame: Juan :owned:
You want to do this for looks, but yet your going to look like a TOOL when you insert the key, turn it, and then press a useless button. If your going to do this, you should add a fart can and giant wing "cuz their legit bro" (in ricer speak).
:rice: :brice:
--2006 Silverado LT-3/3 RCX Lift, Bilstien 5100's, CAI, Exhuast, BFG A/T's,
Tuners Inc. dynotune, Aeroforce Interceptor, Kicker 10" TC, iSimple Interface
--1989 Camaro RS-LT1/700r4 drivetrain swap, Corvette trans internals w/2200 stall,
rebuilt engine with LT4 cam
01bonne
Year and Trim: 2001 SLE
Re: Start.
Post by 01bonne »
Go for it, your bonneville will be unique. As far as being useless I dont think so, i have a kill switch and have to do the same thing to start my car
Night Hawk, The 4 door coupe
2 12" Pioneer Premiers in a vented box $350.00
2200 watt comp mono amp $200.00
7 inch Power Akoustic touchscreen 400.00
Setting off countless car alarms and making my passengers ears bleed... PRICELESS
Bugsi " then you could achieve that with fewer subs and still have (some) trunk space left over to carry groceries/body parts/etc"
LeSabre in Buffalo
Year and Trim: 2012 Eco
Re: Start.
Post by LeSabre in Buffalo »
If you have lots of loooooong lights in your area, I could totally see doing this to save a few bucks at the pump.
Now a start/stop switch is something to consider. Then you keep the ignition key glued into the igntion, and have to merely press a button.
Sadden
2006 Grand Prix GXP
Re: Start.
Post by Sadden »
Proximity one is in the plans for the future.
This would just sort of be a prologue.
We'll see how much energy i have in the next couple days.
