What's the heaviest load you've carried in the trunk?
Re: What's the heaviest load you've carried in the trunk?
All you had to do was come get the Transport
- Melissa
- GXP Member
- Year and Trim: 2000 Bonneville SLE
I'd say my ass but that's a wide load not necessarily a heavy load! haha Sorry I had to chime in!
2000 SLE
Oh Boy, don't get me started
- GoldenBullet
- Year and Trim: 2001 GMC Yukon XL
I think I've had 6 bags of 50lb rocks in my truck before, didn't have a problem with it. Granted my ELC doesnt work.
-Matt
- Melissa
- GXP Member
Wait a minute! How would you know for sure?!?! =P Or you just have jokes up your sleeve!!?Jrs3800 wrote:Oh Boy, don't get me started
2000 SLE
I have a very polluted mind
I regularly toss 320 Lbs in the trunk with no issuesGoldenBullet wrote:I think I've had 6 bags of 50lb rocks in my truck before, didn't have a problem with it. Granted my ELC doesnt work.
- Melissa
- GXP Member
Haha alright, I'm not getting anything started then... dunno that I could handle it!
2000 SLE
wjcollier07
- Year and Trim: ____
In the whole car, 6 people, 350 lb trunk (suitcases), in the range of 1150 lbs of people,...roughly just under 3/4 ton payload...this was in the 93 SE...and it actually handled it quite well.
Most I've had in the SSE so far is 4 people (800 lbs), plus what was in my trunk at the time (150 lbs) The ELC (when it was still working) actually didn't complain too much, but it definitely bottomed out a few times from the gas portion of the struts being cooked so thoroughly.
Had over a ton in the back of the avalanche, plus people before...put us roughly at 8500 lbs gross, 1500 above its 7k GVW rating.
Even its rather large brakes weren't thrilled.
John
- willwren
- Retired Admin
I hit 710 in the trunk today.
Keep in mind big loads in the back seat don't count. That's forward of the rear 'axle'. I'm talking about trunk only loads.
tan96ssei
- GXP Member
- Year and Trim: 1996 SSEi
i had two 500 pound waverunners trailered and a 4T60E-HD in the trunk.
Aerospace Propulsion Technician USAF
Airman First Class,
.:Michael Lyons:.
parts available on 96 see thread viewtopic.php?f=27&t=15185
Airman First Class,
.:Michael Lyons:.
- willwren
- Retired Admin
I have a trailer too (hitch only on the SLEeper), and there's a big difference between tongue weight and trunk weight. I'd betcha my load today was heavier in the trunk than your trans and loaded trailer.
I've pulled a full ton in my trailer on several occasions, but carefully loaded to control that tongue weight. Always short trips.
- willwren
- Retired Admin
Soon. Gotta finish off the joints in the last 3 courses of bricks.
- willwren
- Retired Admin
Not bad for original ELC struts (not to mention still functioning CCR)
710 pounds, 12 ounces:
That's 100 four-pound bricks, four 50 lb bags of gravel, one 50 lb bag of sand, and a 60 lb bag of mortar mix.
Blown93SSEi
- Year and Trim: Dark Green 1997 SSEi
Thats 14.28 cents a pound!willwren wrote: That next 320lb load will only be another $22.40. Helluvalotta weight for so little money.
Jacob, Dark Green 1997 SSEi "The Green Lantern" Over 268,000 Miles and Still Going Strong!
Mods/Stuff: INTENSE! FWI, ScanGauge 2, Mobil 1 HM Oil, Valvoline HM Transmission Fluid, Mildly Tuned PCM, Drilled 180 Thermostat, Cleared Corners, Silverstars, Chrome T-Stars, NGK Iridium Plugs, NAPA Belden Wires.
- GoldenBullet
Who needs lowering springs?
-Matt
- willwren
- Retired Admin
I can tell you from what I know now that I'd never do this on FE1 or on FE2 without a working ELC system.
- RJolly87
My shocks don't hold air, they leak down about as fast as they air up, and I start having problems with more than a child in the back seat. So I would definitely not be doing that.
~Randall~
- zuper8
- Year and Trim: 96 SSEi- 157K
dang that's impressive.
i've had a transmission in the back... but that's about it. i bring a lot of tools home when i visit my parents, but they prolly don't outweigh a trans. my ELC is busted and i need to finally install my little bypass kit thingy
