What's the heaviest load you've carried in the trunk?
willwren
Post by willwren »
Specifically a Bonneville. I'm curious for a reason I'll reveal later. I know some have hauled short blocks, what do they weigh? Anyone haul heavier than that?
Re: What's the heaviest load you've carried in the trunk?
How many pounds of bricks do you want to put in there?
I've had 4 bags of horse feed and one of dog food at 50 lbs each, so about 250 lbs, and that was no sweat.
BlackHawk99
Senior Moderator
Senior Moderator
Year and Trim: _
Post by BlackHawk99 »
455 Pontiac block with the heads, crank, and cam. No intake, oil pan, carb, exhaust manifolds, etc. though. The cherry picker was disasmbled in the back seat since I had to take it with me to pick up the block ~70 miles away. Car drove really weird with all that weight, but it did the trick!
Still a helluva lot of weight (you do the math on the total weight)!! That was in the 99 SE in 2005.
WhiteArrow3800
Post by WhiteArrow3800 »
Put a 3800 short block in the back of the '93, Then put the '93 on a trailer. Does that count?
willwren
Post by willwren »
Mark, can you estimate that 455 load? The picker in the back seat would only account for about half it's weight being forward of the rear 'axle'.
My trailer is only a mile away, but we're in the middle of a NASTY storm, and I don't want to drive in a sloppy yard to hitch it up.
Bricks weigh 4 pounds each, and I need 150 (600 pounds for the math impaired). The bag of mortar can go in the back seat. I'm tempted to run two loads (Home Depot is only a mile away), but if we get a good break in the weather here, I'm going to want to do the whole load at once.
ELC does work on the SLEeper, although they are original rear struts.
swampthing
Post by swampthing »
how about yanking the back seat out and putting some of it in the floorboard to more evenly distribute the load>
Current fleet:
600 lbs is like having a car full of guys, although it is leveraging differently. That doesn't sound too bad.
Blown93SSEi
Year and Trim: Dark Green 1997 SSEi
Post by Blown93SSEi »
My big fat ass. :-#
Jacob, Dark Green 1997 SSEi "The Green Lantern" Over 268,000 Miles and Still Going Strong!
Mods/Stuff: INTENSE! FWI, ScanGauge 2, Mobil 1 HM Oil, Valvoline HM Transmission Fluid, Mildly Tuned PCM, Drilled 180 Thermostat, Cleared Corners, Silverstars, Chrome T-Stars, NGK Iridium Plugs, NAPA Belden Wires.
BlackHawk99
Senior Moderator
Senior Moderator
Year and Trim: _
Wikipedia says it's upwards of 650 lbs. Plus, some of the weight of that cherry picker was on the rear struts.
I'd go for it. You're only going a mile!
willwren
Post by willwren »
And I've got L67 springs and ELC advantage over your 99SE. Sounds good. I won't mess with my trailer.
olblueeyesbonne
Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Post by olblueeyesbonne »
When my brother was remodeling his house after he bought it two years ago I loaded my trunk full of 10"x10" ceramic tiles from Menards in Alexandria and hauled them home.
IIRC, it was almost 750 lbs worth. My trunk was quite full and I was seriously worrying about bumps on the 30 mile drive home causing a little too much flex after the rear axle.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
I've done an entire disassembled L67... everything
Also a 4t65e-hd in my trunk.
willwren
Post by willwren »
The brick alone will be 600 pounds, and should be a pretty impressive load. I'll shoot a pic. It'll be interesting to see if the ELC can keep up. On the 93, it's always active, but on the 95, it's only with ignition on. I think I'll turn the ignition on before I start loading so it can get a head start.
rrounds
Post by rrounds »
Bill,
You saw how much stuff we put in the trunk and back seat when we go to the BEST MEET in the WEST.
I even think you took a pic of the poor gal and how low she sat.
I would guess that we put well over 1000 lbs in the car. Good thing I have good tires on the car. ;)
ROD
2000 SSEI (SOLD)
rods789 at comcast.net
PB 14.474 @ 96.248 PB 60' 2.168
180 therm AEM DRYFLOW Air Filters
3.33 pulley 3" cat back exhaust
custom solid front motor mount
custom 6" (BIG) intake
__WCBF '06, '07, '08, '11 survivor__
LeSabreUltra
Post by LeSabreUltra »
Oh just a couple of dead bodies, nothing too extravagant.
-Dan
_
_
Post by gonzo4191 »
in total, this was in ppl weight, i had about 700 pounds in the bonne, that rear air shocks were loading for a while!
I had 4 guys (900 lbs, probably) and 3 golf bags in my car one day last summer. That was over GVWR. I don't think the engine noticed.
Post by gonzo4191 »
just remember you need more braking distance with heavier loads ;)
Post by Jrs3800 »
Bill on my one bad trip home... I ended up coming home with a complete 3800 in the trunk.. All of my tools( 100-120 Lbs ) My Big Milk crate of happy car stuff( PCM was #1 on that list )... Luggage, Coolant, windshield fluid washer... 2 Packed full suit cases... And in the back seat well I could hardly see out the rear window... :roll: It took 50 Psi just to make the back end level...
willwren
Post by willwren »
Ended up loading only the first 70 bricks and a 60lb bag of mortar mix. I'll get the other 80 bricks when these are almost used up.
Glad I did, ELC is getting tired, and it wasn't quite level. I ended up with about 350lbs. Next load will be 320. I only had to go a mile on city streets, didn't really notice the weight other than the back of the car was about 1/2" lower than usual. I probably could have done the whole thing, but didn't feel like unloading all 150 in the rain today. We'll probably look for an opportune break in the weather for the rest.
That next 320lb load will only be another $22.40. Helluvalotta weight for so little money.
