brakes and abs issues
sTonedefone
- LE Member
- Year and Trim: 1990 Bonneville SE stock 118,000mi
Hey guys im having a real issue with my teves abs. Every time i touch the brake, the abs and the brake light come on. I can vaguely hear the pump, then the lights go away and i can brake normally. If i try to hit the brake too fast i get a funny feeling in the pedal and no brakes for about 1 second; then the pedal comes up and brakes normally. The thing is, even in the rain i can't brake hard enough to invoke the abs because the lights come on and it gets disabled. The fluid level is max and does not change, so i dont think i have a fluid leak. And if i had an accumulator leak, wouldnt the pump come on on its own? I just turned the rotors, put new pads, and clean & adjusted the rears, then bled all the brakes. The pedal is a little higher, but the problems persist. I hope its not a master cylinder - dont they run about 800 bucks? ANY help would be appreciated. my bonne is a 90 se w/abs all stock.
Last edited by SingsCountry1967 on Thu Jan 15, 2009 11:01 am, edited 1 time in total.
SingsCountry1967
- Retired Moderator
- Year and Trim: 2000 SLE
- Location: North of Buffalo, NY __Been there, done that, got the t-shirts
Re: brakes and abs issues
I didn't know what "Teves" was...so I researched... hydroboost brakes do not run on vacuum lines according to the below link. They are pressured by the power steering pump... so... maybe check your power steering fluid level too... http://www.superchevy.com/technical/cha ... index.html
Also: Trouble Shooting Power Brakes (includes Hydroboost brakes) http://www.aa1car.com/library/pwrsteer.htm
'00 SLE Maple Red -"Crisis Management" - (125k)- Customized in Silver... Driven with Excitement. RIP 2013 the Crisis is Over
Plugs/wires @ 51k, UIM/LIM gasket @ 59k. Ignition Ctrl Modual @ 109k '04 Monte Carlo SS - "Dream Chaser" - 3.8L SII - (82k miles)...Purchased 8-7-08...Still Driving!
sTonedefone
- LE Member
the Teves system has a dedicated pump, and a hydrualic accumulator
http://www.505turbo.com/forum/uploads/p ... 982205.jpg
this (at least i hope the link works) is a pic of the master assembly, the black round thing is the accumulator, used to hold pressure, the round cylinder along the bottom, kinda looks like a starter solenoid, is the pump, only on the Bonne its mounted on the fire wall just to the left of the master
- Year and Trim: .
We need to continue this discussion in one place. Could you please continue it here:
viewtopic.php?f=20&t=1366
