Vacuum line elbows and t connector for 1995?
Twystedhemp2
- Year and Trim: 1995
Where can I find these connectors? The 90° elbow into the throttle body, the T-connector into throttle body that goes to FPR and the smaller 90° going into the FPR, and the large connector from the booster into the back of the engine.
- 95naSTA
- Year and Trim: 95 SLE
Re: Vacuum line elbows and t connector for 1995?
The T connectors are on ebay for ~$7
p/n 24502852
I can't find the other one new.
p/n 24502852
Twystedhemp2
Thank you!!
ron350
- Posts like an LN3
- Year and Trim: 1996 Regal Custom
95naSTA thanks for posting the part # for the rubber throttle body T GM 24502852 just ordered one off ebay $6.11.
In the past I was ordering the complete assembly # 24506302 over $20.
Twysted did you find the part # for the fuel pressure regulator elbow?
- 95naSTA
No problem guys.
For the FPR, one of the fittings in this kit should work. Advance Auto has them for $6 locally by me.
https://www.dormanproducts.com/p-26177-47431.aspx
Twystedhemp2
Ah, I think that is the set I got from a parts store last time. The second one in the picture worked well but it cracked right at the bend again.
ron350
- Posts like an LN3
Thanks the vacuum T from ebay looks good and fits.
