OBD PLUG ISSUE
omargadea12
Year and Trim: 95 Pontiac SSEI Supercharged 3.8L
OBD PLUG ISSUE
Post by omargadea12 »
Hello everyone and Happy Holidays! I have a 95 bonneville ssei woth an OBD2 plug. When I have a check engine light nobody can read the codes, they can read other data but cannot get codes, I even had a friend try with his $2000 scanner and it would not read. If any one can help with any ideas or if anyone knows what scanner I can buy. Thanks for the help.
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Re: OBD PLUG ISSUE
Post by MKMike »
You can look for an Actron 9145 scanner --probably only available used on Ebay--or buy a Tech 2 .
94 and 95 are often referred to as OBD 1.5
