Subframe advice. Rear holes.
SSEBonne4evr
- Posts like an LN3
- Year and Trim: 99 Bonneville
May have to fabricate a washer as my rear outer subframe is dropping
due to a trotted hole.
Question: Do the keyed flats on the rear holes go front to back, or right
to left?
I plan on making a plate that fits the inner contour of the frame.
to left?
90 SSE Bonneville Sold but not forgotten.
- 95naSTA
- Year and Trim: 95 SLE
Re: Subframe advice. Rear holes.
It's looking like front to rear in a pic in this thread:
http://www.pontiacbonnevilleclub.com/fo ... ml#p304343
SSEBonne4evr
- Posts like an LN3
OK thanks, looks like I may have to fabricate something and place it below the frame.
Is the lower rubber hard to separate?
96 SSEi
- Posts like a Northstar
hi, up here in Canada, we have places like -bolts+ and brafasco - they sell fasteners and stuff.You must have the same in us - do a search on the internet and you wont have to fab. anything
MKMike
- Posts like an L67
- Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
You may find this thread helpful http://www.pontiacbonnevilleclub.com/fo ... ut#p348281SSEBonne4evr wrote:OK thanks, looks like I may have to fabricate something and place it below the frame.
The subframe is actually 2 pieces. You can replace the rear portion where the bearing holes rot out.
You might look for one from a warmer state. Sometimes you can find them on Ebay.
- Roadrunner
- Posts like an LN3
- Year and Trim: 03SSEI, 00SSEI, 92SE(sold), 93SSE/SC, 87GTA, 01TA
At some point in the mid 90's they switched to a 1 piece frame. I always assumed that they switched to 1 piece for the Series 2 cars but I'm not sure ot that.
If you haven't already, I would first try to get the bolts out one by one. Do one & if it comes out, put it back in with antisieze on threads and go to the next.
If the blind nut inside the body has broken loose and bolt just spins then you have an additional problem to face.
- J Wikoff
- Year and Trim: 1992 SSE
I got a rust free subframe from a yard in South Carolina on eBay recently. Shipped, it was $240 or something like that. At the time, they had a bunch listed, and represented the bulk of the listings.
SSEBonne4evr
- Posts like an LN3
Wow these are all good points.
I have to get under there and see if it still was a 2 piece frame in 96.
That would be so much easier.
I fabricated a large 4" washer under the frame. Surprisingly it worked.
Ground the OD to fit the underside frame cavity and the subframe is not going anywhere now.
Ride smooth with no noise, I could easily have this washer welded in from the underside.
Next nice day I will get it on ramps and check the rest of the mounts.
I do need an upper rubber bushing on one mount near the motor, heat must have took it out.
MKMike
- Posts like an L67
1998 SE
2001 SSEI
2002 SSEI
No, they did not.Roadrunner wrote:At some point in the mid 90's they switched to a 1 piece frame.
You may be confused by the fact that the subframes did change in the mid 90's but they were still made in 2 bolted together pieces.
I've done the subframes on a 93 and on a 98 ;Both were 2 piece subframes.
They disassemble at a point closest to the driver on the driver's side and a point near the radiator on the passenger's side.
SSEBonne4evr
- Posts like an LN3
work is progressing on the subframe. Got entire right side done, complete with
4" washers.
Come up short I rear upper rubber insulator bushing.
Anyone have one lying around from a previous project?
Just re-using the lower bushings.
4" washers.
