Comes out in a few weeks
http://www.oeradio.com/product_GM-5100.html
Direct fit for the GM chassis; their site is a bit short on information, but it does have iPod and Bluetooth connectivity. No sound shaping, five pre-amp outputs. Their site says it has the capacity for steering wheel controls.
I've written to them about compatibility with OnStar, door chimes, HUD and the XM module.
Interesting new factory head unit replacement product
- drdivo
- Year and Trim: 2005 Bonneville GXP Crimson Red Tintcoat
Respectfully,
The Divo
2005 Bonneville GXP "Red Rocket II"
Fram cabin air filter
Fram Air Hog
Kuda USA pad
Sony XDP-PK1000 Digital Link
Kicker KS65 x 6 speakers
The Divo
Fram Air Hog
Kuda USA pad
RJGill84
- Year and Trim: 2001 Pontiac Bonneville SE
Re: Interesting new factory head unit replacement product
I'd be VERY interested in this if it will work in 00+ Bonnevilles. But I question if it will since it only lists 2005 and newer vehicles. Most 2005 and new GM products have the GMLan system, which our Bonnevilles do NOT have - even 2005s. You're better off with the TNR800 or some other GM OEM unit.
"SLE without the ugly" - leather, climate control, sound, 3.05 gearing, 180* t-stat, tints. http://www.gillsystems.com
- drdivo
interestingly, from everything I could find out, this unit won't really work with our Bonnies. The unit won't reproduce the door/key chimes, nor will it maintain the OnStar.
Respectfully,
The Divo
Fram Air Hog
Kuda USA pad
The Divo
Fram Air Hog
Kuda USA pad
petraman
- Year and Trim: .
2013 Audi A4 6MT - Location: ............ Granville, Ohio/Erie, PA *WCBF '08 SURVIVOR* *NEBF '07 SURVIVOR*
Intriguing... But from what I can tell, you'll still need to buy a harness... It would be an engineering nightmare trying to design that around GM's LAN bus system... So (sadly the dingleberries forgot to take more than one picture of it), without seeing the rear (where the harness would theoretically be sticking out from), I would assume that it would work with the Bonneville. It does look like it has the brackets built in, though, so some fabrication might be in order... But, that's just a guess, let's see what the Dr. comes up with in his email reply...
