Gen V vs. Gen III
Zeik75
Year and Trim: 1988 LE
Gen V vs. Gen III
Post by Zeik75 »
What exactly is the difference in the snout, housing, rotors? I know the series 3 used the drive by wire throttle body, but is that the only difference?
I ask because I have 3 M90's but one was a spare and i'm not sure what engine it came off of. It does look a bit different though, it has a blue steel kind of paint on the whole housing and snout. Would this be a Gen V? I was told It was going to go into a 2003 GP if that helps.
-Austin-
yourgrandma
Year and Trim: '02 SSEi
Re: Gen V vs. Gen III
Post by yourgrandma »
Easiest giveaway is probably the lack of a threaded hole on top of the gen v. Everything is different between the two, but thqts the easies giveaway off thebtop of my head.
bobtaz13
Year and Trim: 2001 SSEi
1991 SE
Post by bobtaz13 »
Posting photo's of each would be just as easy
2001 SSEi | Galaxy Silver | GenV supercharger P&P | Intense 3.2 MPS | Intense FWI 4"| Custom PCM | TOG Ceramic headers | Magnaflow 3" cat | 180° stat | Aeroforce scan gauge | PRJ plug wires | PRJ fuel rails | Silicone vacuum lines| AP103 plugs | 3.2 MPS | 42.5# injectors | Intense 1x cam kit | YT 1.8 Rockers | 105# springs | Meziere HD pump | N* Tb | 185mm MAF | 2" Phenolic Intercooler | Oil pressure kit | L32 short block | 5% overdrive SFI Balancer | L67 heads custom ported | EBC USR Rotors | EBC Red stuff pads | Custom HID Fog lights, with HI-beam over ride | Polyurethane motor mount | Energy Suspension end links | GXP Shocks/Struts | Custom Drop springs Front, Rear FE5 Springs | GXP Strut tower Brace | GP GXP 18x8 Rims | Polished Exhaust tips | Triple Edge High Performance Street/Strip 4T65E-HD |
GenIII
GenV
Zeik75
Post by Zeik75 »
I'll have to check when I get home i just remember glancing at it in the dark when i went to get something from the shed the other night and somethin looked different.
-Austin-
They both do the same thing, the Gen V does it more efficiently.
I remember reading somewhere that even a ported Gen III won't touch a Gen V.
MattStrike
Year and Trim: '99 Montana
'92 Trofeo
Post by MattStrike »
What about a ported Gen III with new rotors that have the gen 5 coating ?
Backhoe
Year and Trim: '98 LSS L67
Post by Backhoe »
MattStrike wrote:What about a ported Gen III with new rotors that have the gen 5 coating ?
I think that makes it a GenV to me, I thought it was the coating.
1998 Olds LSS/L67, 92K miles, Intense FWI, SSAC headers, 3.2 MPS, cat delete, 180 stat, AL 103's, HPT.
1996 Olds Eighty Eight LS/L36, 146K miles, mostly stock
1997 Olds LSS/L36, 95K miles, raided for dent free parts and sold
1989 Bonneville LE Gem (sold)
1987 Bonneville LE (retired)
olblueeyesbonne
Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Post by olblueeyesbonne »
75mm vs 65-67mm inlet
outlets
These two differences make up a big part in the superior efficiency of the Gen V over Gen III.
Even a fully ported Gen III doesn't match the capabilities of a stock Gen V.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
FasGP
Year and Trim: Pullied Clean 2k Black SSEi...
Post by FasGP »
Into perspective, a stock Gen V was 20hp more than a stock Gen III car. Other than the drive by wire, and factory U bend delete, everything else was the same. Typically, stepping down a Gen V to a 3.4 pulley was like running a 3.2 pulley on a Gen III. Its all about improved design, inlet/outlet sizes, and efficiency.
yourgrandma
Outlet is way different, inlet is bigger and smoother,also the coating. Quite a lot is different.
