92 Regal L27 idle issues
Merrillspontiac
Year and Trim: 2000 Pontiac Bonneville SE
Post by Merrillspontiac »
My 3800 has recently developed a weird idle issue when warm, it will idle rough but when I remove the oil cap the idle smooths out. Bad pcv valve a possible cause?
1993 Buick Regal GS Coupe
94SilverSSEi
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
Re: 92 Regal L27 idle issues
Post by 94SilverSSEi »
92.1 or 92.2?
PCV is easy enough to check, pull it and see if it rattles. Only costs a few bucks if you want to replace it for good measure.
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
Merrillspontiac
92.1, under acceleration it runs just fine and has plenty of power, it just idles rough.
94SilverSSEi
68 w/400
94 SSEi
Engine light? Codes?
Clay
Merrillspontiac
neither, now the right front turn signal is burned out, lol.
94SilverSSEi
68 w/400
94 SSEi
Gotta love that car though. I think EVERY part on it, aside from the motor/trans has been replaced/repaired or fudged at one time or another.
Still daily drive it?
Edit: Have you checked all the vacuum lines and connections. I would think if that was the issue you would notice it when driving too, but its worth a shot.
Last time I pulled those lines off my 1997 they turned to dust. Yeah, that was fun trying to find replacements.
Clay
Merrillspontiac
not lately I plan on it for winter tho.
Bob Dillon
Post by Bob Dillon »
94SilverSSEi wrote:92.1 or 92.2?
Replace both O-rings-the one around the PCV valve itself and the one that seals the chamber at the top. For that one, you'll need a 38MM by 4 MM O-ring. The local Ace hardware has them in the Dorman section. Also, make sure the MAP sensor doesn't leak and is correctly seated.
Based on my recent experiences, you should really replace all the vacuum lines.
Merrillspontiac
Where is the map sensor on an L27?
Tim's Buick
Post by Tim's Buick »
I don't think there is a map sensor on any 3800 lol. Isnt the pcv integrated into the head and intake manifold? I know it is on my 93.
09 Pontiac Vibe AWD
01 Pontiac Sunfire GTX
84 Chevrolet Citation
94SilverSSEi
68 w/400
94 SSEi
L36 Map is on top of the PCV area. Not sure about the L27 though, maybe doesn't have one?
Clay
