HVAC Blower motor has a mind of its own
My 2003 SLE has the climate control. It will show that the fan should be operating on high and sometimes it runs and sometimes it doesn't. Sometimes it will come on or shut down when I 'm going down the road. Any advice?
joeymdorsey
- LE Member
- Year and Trim: 2004 bonneville sle
Re: HVAC Blower motor has a mind of its own
had the same problem with my 04
blower motor had worn brushes.
not sure if thats your prob, but i replaced the motor and now it works fine.
- nos4blood70
- Year and Trim: 2003 SLE
Same problem happened to me, replaced the motor, problem solved! It's a simple fix too.
I'm on like 3 years with mine acting up. It works fine, but when it's really cold I usually have to smack the dash hard to get it to start up. I could tell this past year it's getting on it's last legs as it didn't blow as hard, and the heat doesn't really kick in until I turn it up above 80. I just need to to make it one more winter.
- nos4blood70
It's such a super easy replacement on the 2003. Why torture yourself?
