low voltage
failure
Year and Trim: 1993 bonneville SSEI
low voltage
Post by failure »
Hey guys my car keeps telling me low voltage. It only happens when I get on the gas hard and it gets high on the rpms. The light will stay light for about a min or so and then go off. Bad alt or what the battery has 14 volts while idling.
Re: low voltage
Go to AutoZone or Advance and get a test done. Could be a list of things.
mylittleblackbird
Year and Trim: 1995 LX(went to the shredder)*sniffle*
1999 SE
Re: low voltage
Post by mylittleblackbird »
:withstupid: Obligatory.
I have a Bonneville, it's white and N/A! :twisted:
Mod List: Hood and Fender "adjustment" - "Enhanced" A/C compressor clutch - Extra loud PS Pump - Mega sensitive CKPS - Audible Rear Drums - Lowered headliner - Custom stained upholstery - "Brown Devil" weight reduction kit - Low Friction Belt. More to come!
Bugsi
05 Mercedes S500 4Matic
Re: low voltage
Post by Bugsi »
Possible culprits:
Battery: Have it load tested.
Alternator: Have it tested.
Corroded cables: Check the positive battery cables especially. Slit back the insulation and inspect for greenish copper corrosion in the wire. If it's good, repair the insulation slit by wrapping with electrical tape.
Corroded grounds: Check the ground busses for corrosion under the carpet in the front footwells.
`05 Mercedes S500
1oldman
Re: low voltage
Post by 1oldman »
Bugsi wrote:Possible culprits:
from my experience, Bugsi has covered everything I would have suggested.. - BC
