thermostat ..... 180 or 195 ?
- wdudetocool
- SSEi Member
- Year and Trim: 2000 se
hey guys... i have put a 4t65e-hd tranny on my non-supercharged engine. <which works beautifully-thanks again harodude> my question is do i want to keep the 195 thermostat in my engine ,or should i put the 180 one in? i ask because i read that the hd trannys are designed to run cooler than the non hd tranny, which i would have thought the other way around.....
Re: thermostat ..... 180 or 195 ?
I'd go with the 180 to keep everything a little cooler all the way around. I put a 180 in mine and the coolant tends to run around 195. Never checked what the 195 kept the coolant at but I imagine it was around 205-210. It won't hurt to keep everything cooler it may even last a bit longer.
- crash93ssei
- Retired Moderator
- Year and Trim: 2002 SE
Both are fine, you will basically notice no difference with either.
- FasGP
- GXP Member
- Year and Trim: Pullied Clean 2k Black SSEi...
180 is the way to go. An aux trans cooler is even better way to take care of that trans, cause the stock one has always been a poor one.
2003 SSEi
- Posts like an L67
- Year and Trim: 2003 SSEi.
LOTS of Mods
IF you dont have the Tune changed to have the Fans turn on @ 180*, then that Thermostat really doesnt do that much.
