What should my tire pressure be
bobjones003
- Year and Trim: 03 Bonneville se 138500 jbl speakers apline deck
I have 03 bonnieville the tire pressure tag is tore off on the driver door. What should my tire pressure be? I have them inflated to 32
2003 Pontiac Bonneville se Mods JBL speakers and apline deck cde-121. More to come in coming months
Re: What should my tire pressure be
I don't know the factory spec, but the best way is to keep an eye on them and monitor wear and mileage. 32 is a good rule of thumb, on my SSEi I keep them around 35 to reduce sidewall roll.
- repinS
- Moderator
- Year and Trim: 09 G8 GT
Ditto. Keeping them at 35 may also compromise ride quality somewhat, but it's something that I can live with. YMMV.00Beast wrote:I don't know the factory spec, but the best way is to keep an eye on them and monitor wear and mileage. 32 is a good rule of thumb, on my SSEi I keep them around 35 to reduce sidewall roll.
justin85
Open your drivers door an look on the end of door or along the b-pillar where door closes. That sticker will tell you factory tires size an pressure.
His first post says that his isn't legible anymore. It should also be in the owner's manual.
- StreetƐgl-o21
- Year and Trim: 1994 Pontiac Bonneville SE
35 Is what i keep mine at. Sometimes a little more because i like the firm feel but it believe it is 35.
A.Marie- 1994 Pontiac Bonneville SE- 271,865mi.
K&N Performance A.Filter,
JVC-KDR-530 Head Unit (soon to be replaced w/Alpine CDE-HD138BT)
Alpine (SPR-50C)Type R 5-1/4" 2-Way Components (Front), Kenwood(KFC-G6930) - 6" x 9" 3-Ways(Rear Deck)
Mine is at 35psi as well and i also have Nitrogen inflation at my work so thats what i have, that keeps my stupid tire light from coming on as often when it gets cold (nitro and 35psi).
Shane "RedZMonte"
2004 Z16 Z06: Virgin
vogie01
- Posts like an L27
- Year and Trim: 2002 SLE
I am an odd ball. 34 psi for this guy.
Since I can't afford nitrogen, I always make sure to drain out the summer when it gets cold and and put in winter air. Otherwise it will freeze.
swampthing
I typically run about 37-38 but i am on 18s with a little less sidewall
Current fleet:
Current fleet:
- crash93ssei
- Retired Moderator
- Year and Trim: 2002 SE
I guess I am a real oddball, I run 40 in all tires unless the max rated PSI is less then that.
97ParkAve
- Year and Trim: 1997 Park Avenue (Base)
1986 Ford Mustang GT - Location: New Jersey
225/60/16 should be at 30 PSI
justin85
Lol I just re-read bobjones post lol ya should be in owners manual lol sorry about that apparently my brain and eyes shut down after 5pm lol
