What should my tire pressure be
bobjones003
Year and Trim: 03 Bonneville se 138500 jbl speakers apline deck
Post by bobjones003 »
I have 03 bonnieville the tire pressure tag is tore off on the driver door. What should my tire pressure be? I have them inflated to 32
2003 Pontiac Bonneville se Mods JBL speakers and apline deck cde-121. More to come in coming months
Re: What should my tire pressure be
I don't know the factory spec, but the best way is to keep an eye on them and monitor wear and mileage. 32 is a good rule of thumb, on my SSEi I keep them around 35 to reduce sidewall roll.
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Post by repinS »
00Beast wrote:I don't know the factory spec, but the best way is to keep an eye on them and monitor wear and mileage. 32 is a good rule of thumb, on my SSEi I keep them around 35 to reduce sidewall roll.
Ditto. Keeping them at 35 may also compromise ride quality somewhat, but it's something that I can live with. YMMV.
justin85
Post by justin85 »
Open your drivers door an look on the end of door or along the b-pillar where door closes. That sticker will tell you factory tires size an pressure.
His first post says that his isn't legible anymore. It should also be in the owner's manual.
StreetƐgl-o21
Year and Trim: 1994 Pontiac Bonneville SE
Post by StreetƐgl-o21 »
35 Is what i keep mine at. Sometimes a little more because i like the firm feel but it believe it is 35.
A.Marie- 1994 Pontiac Bonneville SE- 271,865mi.
K&N Performance A.Filter,
JVC-KDR-530 Head Unit (soon to be replaced w/Alpine CDE-HD138BT)
Alpine (SPR-50C)Type R 5-1/4" 2-Way Components (Front), Kenwood(KFC-G6930) - 6" x 9" 3-Ways(Rear Deck)
redzmonte
Year and Trim: 2000 SSEI
Post by redzmonte »
Mine is at 35psi as well and i also have Nitrogen inflation at my work so thats what i have, that keeps my stupid tire light from coming on as often when it gets cold (nitro and 35psi).
Shane "RedZMonte"
2004 Z16 Z06: Virgin
vogie01
Post by vogie01 »
I am an odd ball. 34 psi for this guy.
Since I can't afford nitrogen, I always make sure to drain out the summer when it gets cold and and put in winter air. Otherwise it will freeze.
swampthing
Post by swampthing »
I typically run about 37-38 but i am on 18s with a little less sidewall
Current fleet:
crash93ssei
Post by crash93ssei »
I guess I am a real oddball, I run 40 in all tires unless the max rated PSI is less then that.
97ParkAve
Year and Trim: 1997 Park Avenue (Base)
1986 Ford Mustang GT
Post by 97ParkAve »
225/60/16 should be at 30 PSI
justin85
Post by justin85 »
Lol I just re-read bobjones post lol ya should be in owners manual lol sorry about that apparently my brain and eyes shut down after 5pm lol
