Sea Foam precautions/recommendations?
- Allmachtige
- Retired Moderator
- Year and Trim: 2009 G8 GT
I picked up a can and am performing some basic maintenance after my trip to Canada. I'd like to give this a shot, but want to be sure its not going to damage anything.
Looks like most members pour a 1/3 of the can into the supercharger via the brake booster vac line. Is this the best method? It also appears I need to do this until the engine bogs down and dies, then pour some in the gas tank as well.
Am I following the correct procedure?
2009 G8 GT - White Hot
FMS Custom Cam, Yank 3600 SS, 1LE (ZL1) 3.91, SLP Longtubes, Magnaflow cat-back, Rotofab CAI, tuned via HPTuners
415/391
415/391
bonnevillain
- Year and Trim: 2002 SLE
Re: Sea Foam precautions/recommendations?
you can stick the brake booster in the can, but i have seen the can implode from all the suction when doing this. I prefer to pour 1/3 of the can into a cup, rev it to about 2K rpms and suck it out of there with the brake booster line. The car will most likely stall, if not just shut it off real quick. Let the car sit about 10 minutes, and then take it for a spirited drive.
Putting some in the gas tank will clean the fueling system and is unrelated, but it couldn't hurt as long as you have a can of it.
- Whitecrystal1
- Posts like an L36
- Year and Trim: 10 Silverado
2002 Buick Lesabre Custom L36 Titanium Blue Metallic/Medium Gray Cloth
2004 Buick Lesabre Custom L36 White/Graphite Gray Cloth
2015 SS Roof, Spare & 6M 6.2L LS3 415HP/415TQ SLIHRM/Jet Black Leather-Red Stitching
2010 Silverado LTZ Crew 4x4 6.2L L9H 417HP/403TQ NHT Black Granite Metallic/Ebony Leather
2013 Enclave Premium AWD 3.6L LLT White Diamond Tricoat/Cocoa Leather
2001 Wellcraft Martinique 2400 Merc 5.7L BIII 327hrs
1995 Bonneville SSE L36 Dark Polo Green Metallic **R.I.P. 4/28/10 236,400 miles**
wjcollier07
- Year and Trim: ____
I just keep a spare length of vacuum line around. I don't like the brake booster line because its hard to gauge how much it sucks up. I take off one, say for the trans modulator or something else unnecessary for it being in park, and plug in mu length. Then I usually just suck it right out of the can, the smaller line doesn't cause implosion obviously.
Then shut off, up to an hour, I'd say 30-45 mins, and take it for a drive. Whatever you do, don't REV it in park, I don't understand when people do that.
Anyways, yeah, drive until the smoke is gone, and repeat if you'd like.
John
- Allmachtige
- Retired Moderator
I did what bonnevillain suggested and put 1/3rd in the cup, then put the brake booster line in there to suck it up.
After an hour I put the rest in the gas tank and started the car...holy smokes batman!
415/391
415/391
01bonneSC
YEAY!!! The ol SEAFOAM SMOKE BOMB!!!
Blown93SSEi
- Posts like an L67
- Year and Trim: Dark Green 1997 SSEi
I'll need one for the meet!01bonneSC wrote:YEAY!!! The ol SEAFOAM SMOKE BOMB!!!
Jacob, Dark Green 1997 SSEi "The Green Lantern" Over 268,000 Miles and Still Going Strong!
Mods/Stuff: INTENSE! FWI, ScanGauge 2, Mobil 1 HM Oil, Valvoline HM Transmission Fluid, Mildly Tuned PCM, Drilled 180 Thermostat, Cleared Corners, Silverstars, Chrome T-Stars, NGK Iridium Plugs, NAPA Belden Wires.
fbn8248
- Year and Trim: 2000 SE
I'm new to this but what is the reason to use this seafoam stuff?
I just bought a 2000 se a few months ago and it still has dex-cool in it and I've been reading as much as I can. I am now planning on changing the uim,lim gaskets flushing the dex-kill and possibly this seafoam stuff but why?
- bill buttermore
- Retired Gearhead
- Year and Trim: 98 Caravan is the daily driver 215K
The Seafoam treatment when sucked directly into the intake manifold via a vacuum line is supposed to remove carbon deposits on the intake passages, intake valves and in the combustion chambers.fbn8248 wrote:I'm new to this but what is the reason to use this seafoam stuff?
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
Rusgreim
- GXP Member
- Year and Trim: White 2000 Bonneville SLE
This is what my throttle body looked like during my UIM / LIM gasket change over the weekend:
I shined it up very nicely, but my question is: even though the UIM is new and perfectly clean, the rest of the engine is not. If I do a Seafoam treatment, is all that going to end up in my cat and all over my o2 sensor?
Russell (Rus or Rusty)
White 2000 SLE - 161k Miles
Current Mods - Transgo Shift Kit, 180* Drilled Thermostat, NGK TR55 & Belden Plug Wires, Suspension Energy Endlink Upgrade, "Stock" 12-Way Power Seats, "Stock" Heated Seats, "Stock" Homelink GDO, Cleared Corners, Pins & Dealer Badge Removed, 2002 56I Center Console, Dash Trim, Steering Wheel and Shifter Swap, Auto-Dimming RV Mirror, Pioneer AVH-P4000DVD MP3/USB Headunit w/ Steering Wheel Controls and iPhone Music Interface, Hood Protector, Gutted Airbox w/ K&N Filter.
Mods in Progress - SSEi Inflator with Stock controls, Chrome "Swoopies" (Have rims, need tires)
Future Mods - Viper 5701 Remote Start with Smart Start and 35% Window Tinting
bonnevillain
the short answer is yes. usually, youre fine. but if you wanted, you could probably just take out (and unplug) the 02 sensor before you do it (i assume it would still run, although it would throw a CEL)
fbn8248
where do you get seafoam?
wjcollier07
Advance, Napa, Checker, etc.
Watch for sales at Advance, sometimes its like 3.99/can.
John
ericm88
- Year and Trim: 2001 SE
Where is one of these vacuum lines to suck the seafoam up? I'm a little confused on that.
2001 Bonneville SE
- K&N Filter Charger
