Does this look right to you?
Saturn Simon
Year and Trim: 1992 SSEi
Post by Saturn Simon »
I recently noticed that my '92 Bonneville doesn't seem to be sitting quite right. The back seems to be higher than the front. I took this photo today:
having said that, it doesn't look as bad as it did the other day, but it is definitely looking a bit too high at the back.
What's causing it?
Re: Does this look right to you?
Sounds like the ELC is a little out of whack...
Maybe she wants to go drag racing! :twisted:
yonkerse
Post by yonkerse »
nos4blood70 wrote:Maybe she wants to go drag racing! :twisted:
Agreed! :D
Eric
A few mods..
Backhoe
Year and Trim: '98 LSS L67
Post by Backhoe »
Have you inspected the ride height sensor? I believe its on the right-rear A-arm, maybe it got knocked out of whack on one of your jaunts through the english countryside? Beyond that I don't know, but I would turn on the ignition, but not start the motor, and listen to how the compressor is working, you'll hear the fuel pump first, then the compressor should kick in at 20-30 seconds I believe. Hopefully you can determine whether or not the compressor is running too long, mine only runs for about 5 seconds after it starts.
Somebody here should have a few more in-depth checks for you, these are just a couple to narrow field of possible culprits.
1998 Olds LSS/L67, 92K miles, Intense FWI, SSAC headers, 3.2 MPS, cat delete, 180 stat, AL 103's, HPT.
1996 Olds Eighty Eight LS/L36, 146K miles, mostly stock
1997 Olds LSS/L36, 95K miles, raided for dent free parts and sold
1989 Bonneville LE Gem (sold)
1987 Bonneville LE (retired)
J Wikoff
Post by J Wikoff »
My sensor arm broke off once in a position that made it think the rear was low, and it pumped the rear up a ways.
nbro3546
Year and Trim: 1997 Pontiac Bonneville SSEI
Post by nbro3546 »
You can always unhook the lines and run new if the shocks are in decent condition. Cheap fix but you have to fill it with air manually after that
It's definitely not the lines or the compressor. It's the ride height sensor or something of that nature. Fairly simple fix I'm sure.
