Fuel Pump Issue
pontiac6269
Year and Trim: 2006 Grand Prix Sedan
1998 Olds 88
Fuel Pump Issue
Post by pontiac6269 »
My 98 Olds 88 the fuel pump won't run. I replaced it last year in Sept. Saturday I started the car, it ran for a couple minutes and then stalled. Cranked over again and just cranked. Turned key back and removed and replaced, cranked again and started and ran fine the rest of the day Saturday, Sunday and Monday. This morning(Tuesday) it did the same thing as Saturday, carnked, ran for a bit, stalled and restarted, I took off up the road for work and got 1/2 a mile before it stalled again. No start can't hear the fuel pump. I checked all the fuses relays, all good, parts store warrentied the pump and got a new one and a filter. Still doesn't prime or come on. Noticed that my power windows and power seat don't work but everything else does, engine cranks over fine. Am I missing something here? What should I check out?
Thanks,
Eric
1969 Pontiac GTO
1978 Olds Cutlass Supreme
1981 Chevy C20
1985 Chevy K5 Blazer
2001 Ford F350 SC Cab&Chassis Dually
2004 Bonneville SE
2008 Grand Prix
Mechanical Mike
Year and Trim: 99 SSEi
Re: Fuel Pump Issue
Post by Mechanical Mike »
99.999 percent chance it's a corroded ground bus on the driver's side.
Image[/quote]
Last edited by Mechanical Mike on Wed Oct 26, 2011 12:43 am, edited 1 time in total.
2006 Chevy Monte Carlo SS
pontiac6269
1998 Olds 88
Re: Fuel Pump Issue
You where right, I pulled the wiring harness out and squeezed it and the pump primed and the windows a seat work. Thanks Mechanical Mike, really apreciate your post and pictures.
Thanks, Eric
1969 Pontiac GTO
1981 Chevy C20
2004 Bonneville SE
2008 Grand Prix
Re: Fuel Pump Issue
Pop the cover off and clean that bar, it's probably all corroded and nasty, and put some di-electric grease on it. Check the one on the other side too.
pontiac6269
1998 Olds 88
Re: Fuel Pump Issue
I pulled the drivers side cover off, supprisingly it wasn't corroded but some plastic melted into one of the terminals, I'll check the other side tomorrow. My rockers are shot so I'll have to check them every once in a while. At least I know they're there.
Thanks,
Eric
1969 Pontiac GTO
1981 Chevy C20
2004 Bonneville SE
2008 Grand Prix
