This car is starting to try my patience, and my wallet, but at this point, I am going to keep plugging at it till its ALL fixed (does that ever happen?)
Cooling fans stay on.
57lxi
- Year and Trim: 1995 Oldsmobile 88 Royale. Rescued from the auction.
I noticied this morning when I fired up the car, both fans came on, high speed. Fan temp switch? Relay?
57lxi
Re: Cooling fans stay on.
.....I know the AC system has a pressure switch that activates the fans, AC works fine. Is there another switch on the engine?
- willwren
- Retired Admin
- Year and Trim: .
Do the fans turn off when the AC is off?
57lxi
No, they stay on high all the time. I was thinking of jumping the pressure swith on the AC to see if they act like they should. Its gonna be a real pisser if the AC pressure switch is bad, just had the system filled.
- azu
- Posts like an L27
- Year and Trim: 03 SE
I had same problem about 8 months ago. It was a broken wire from the pressure swith. Check the wiring but it could be a bad pressure switch. Another possibility, unlikely, could be the system is over charged.
13 Chevy Malibu LS 73K
The only dumb question is the one you didn't ask.
