Trickle charging question
Mac077
- Posts like an LN3
- Year and Trim: 2000 SSEi & 2005 SE
Can you trickle charge the battery through the terminal in the engine bay or do you have to go directly on the battery itself? 6 amp or 2 amp setting??
2000 SSEi (Silver Eagle) cleared corners (before accident) new LIM gasket, drilled 180 T-stat, new plugs and wires, new valve cover gaskets, new Supercharger gasket, third brake light overlay. Hopefully soon to start more mods for performance. Also, 2005 White SE totally stock and will remain that way!
Thank you Bob & Vince for your hard work and kindness!!
- wdean
- SSE Member
- Year and Trim: 2001 Galaxy Silver SSEi
Re: Trickle charging question
You should be able to charge it no problem from under the hood. If you want a slow trickle them use the 2 amp setting. If it keeps going flat then you will have to check the charge rate from the alternator - if its ok, then your battery is toast.
____________
Wayne
Wayne
- 2002BonnevilleSE
- Posts like an LN3
- Year and Trim: 2002 Bonneville SE
I use a trickle charger in the winter when my car is parked till spring. Battery Tender kind.I just use the terminals under the hood. Works fine.http://batterytender.com/
Cadet Blue....Not perfect...But paid for.
K&N Air Filter and Gutted air box. 180 Thermo Cleared Corners More to come.
"Unfortunately there is one thing standing between me and that property: the rightful owners."
- Hedley Lamarr, Blazing Saddles
"One morning I shot an elephant in my pajamas. How he got in my pajamas, I don't know." Capt. Geoffrey T. Spaulding - Groucho Marx - Animal Crackers
- InfiniteRiddles
- Year and Trim: 2002 Bonneville SSEI
I suggest disconnecting the battery.
I once charged mine that way and I got a service stability system soon indication on the DIC. Lucky tho, it did go away after disconnecting the battery. Never tried it again. Not saying this is common, but it happened with me. The battery in 2000+ bonnevilles is just under the back seat anyhow. Should be easy to avoid the possible risk. Thats just me
Infinite Riddles...
Rebuilt top-end, Drilled rotors, Ceramic pads, Ported Super Charger & Manifold, Red L.E.D. Streetglow kit, Silver Star Ultra High/Low Beams, Silver Star Fog-lights, Specter Air-filter, Magnaflow Cat.
My Bonneville Shotz http://photobucket.com/InfiniteRiddle
- 2000Silverbullet
- Retired Gearhead
I use a Battery Tender trickle charger all the time and connect it under the hood without disconnecting the battery. Works fine.
- InfiniteRiddles
Infinite Riddles...
- 2000Silverbullet
- Retired Gearhead
Well, while we're still off topic......Here's a better pic of my rear window and engine bay.
I'm honoured you chose the same name as mine for your Silver Bonne.
- InfiniteRiddles
Infinite Riddles...
