Trickle charging question
Mac077
Year and Trim: 2000 SSEi & 2005 SE
Post by Mac077 »
Can you trickle charge the battery through the terminal in the engine bay or do you have to go directly on the battery itself? 6 amp or 2 amp setting??
2000 SSEi (Silver Eagle) cleared corners (before accident) new LIM gasket, drilled 180 T-stat, new plugs and wires, new valve cover gaskets, new Supercharger gasket, third brake light overlay. Hopefully soon to start more mods for performance. Also, 2005 White SE totally stock and will remain that way!
Thank you Bob & Vince for your hard work and kindness!!
wdean
Year and Trim: 2001 Galaxy Silver SSEi
Re: Trickle charging question
Post by wdean »
You should be able to charge it no problem from under the hood. If you want a slow trickle them use the 2 amp setting. If it keeps going flat then you will have to check the charge rate from the alternator - if its ok, then your battery is toast.
____________
Wayne
2002BonnevilleSE
Year and Trim: 2002 Bonneville SE
Post by 2002BonnevilleSE »
I use a trickle charger in the winter when my car is parked till spring. Battery Tender kind.I just use the terminals under the hood. Works fine.http://batterytender.com/
Cadet Blue....Not perfect...But paid for.
K&N Air Filter and Gutted air box. 180 Thermo Cleared Corners More to come.
"Unfortunately there is one thing standing between me and that property: the rightful owners."
- Hedley Lamarr, Blazing Saddles
"One morning I shot an elephant in my pajamas. How he got in my pajamas, I don't know." Capt. Geoffrey T. Spaulding - Groucho Marx - Animal Crackers
InfiniteRiddles
Year and Trim: 2002 Bonneville SSEI
Post by InfiniteRiddles »
I suggest disconnecting the battery. :btruestory: I once charged mine that way and I got a service stability system soon indication on the DIC. Lucky tho, it did go away after disconnecting the battery. Never tried it again. Not saying this is common, but it happened with me. The battery in 2000+ bonnevilles is just under the back seat anyhow. Should be easy to avoid the possible risk. Thats just me
Infinite Riddles...
Rebuilt top-end, Drilled rotors, Ceramic pads, Ported Super Charger & Manifold, Red L.E.D. Streetglow kit, Silver Star Ultra High/Low Beams, Silver Star Fog-lights, Specter Air-filter, Magnaflow Cat.
My Bonneville Shotz http://photobucket.com/InfiniteRiddle
2000Silverbullet
Post by 2000Silverbullet »
I use a Battery Tender trickle charger all the time and connect it under the hood without disconnecting the battery. Works fine.
InfiniteRiddles
:offtopic: I like your silver bullet car pic, but you know how they have websites devoted to picking out quarky things in movies or tunes? lol I just honed in on your backwindow VS the backdrop lol Epic.
Infinite Riddles...
2000Silverbullet
Well, while we're still off topic......Here's a better pic of my rear window and engine bay.
I'm honoured you chose the same name as mine for your Silver Bonne.
=D>
InfiniteRiddles
:hail: lol yeah seemed like a good name, ill add 2.0 ha also where did u get all the ssei decals under the hood?
Infinite Riddles...
