tires dont peel with WOT
seekinhighhp
Year and Trim: 2001 Pontiac Bonneville SSEi
Post by seekinhighhp »
If the pavement is dry and with the traction control is on/off the tires won't peel at all. I do get full power and the speed I want but the car barely burn rubber. Is this normal?
1997 Pontiac Bonneville SSE (TOTALLED! gone, but not forgotten!)
1993 Pontiac Bonneville SSE SUPERCHARGED (no comment)
1993 Pontiac Bonneville SSEi (sold)
1996 Pontiac Bonneville SSEi (sold....**sniff**)
2001 Pontiac Bonneville SSEi 106K (I'm back in black....YAAAAAY!!!!)
jedwards83
Year and Trim: Currently searching for a Bonneville...
Re: tires dont peel with WOT
Post by jedwards83 »
WOT from a stop is pretty much pointless in my experience because of the wheelspin.
I wouldn't try to create it; it's not a good idea on a car known to shear the differential pin under such conditions.
But no, I don't think that's normal unless the T/C is intervening. Are you at a higher altitude where the air is thinner? That would make a huge difference.
Inferno Red 2009 Dodge Caliber SRT-4 125k
seekinhighhp
I don't do WOT often but it would be nice to hear the tires spin ever once in awhile and not chirp. I stay in Chicago. When I don't give it a lot of gas, the car still has power to pass, get to.55mph with no hesitation.
You should be able to screech them on demand. Sounds like something isn't right.
seekinhighhp
I'll try posting a video through my phone so u all can see and hear what's going on. I don't have an SES light anymore since I changed the catalytic converter and I just recently gutted my airbox. The only tone I notice wheel spin but not a lot on these conditions is when I make a turn and gas on it.
willwren
Post by willwren »
Steve, burning in a turn is the WORST thing you can do to your differential. Unequal loads on each side of the differential will shear that pin. Don't do that any more until you invest in an LSD.
On a stock car it's hard to get rubber from going into it from a dead stop. Turn the Traction Control off, Put your foot on the brake, rev the engine to 2k RPM and punch it as you get off the brake, and you should light them up.
I agree, one-wheel peals and burning while turning are terrible for your diff and trans as a whole.
seekinhighhp
willwren wrote:Steve, burning in a turn is the WORST thing you can do to your differential. Unequal loads on each side of the differential will shear that pin. Don't do that any more until you invest in an LSD.
I'll keep that in mind but, I don't do this often either. Just sharing how my car reacts.
willwren
Post by willwren »
Don't do it EVER Steve. Don't ruin another car.
00Beast wrote:On a stock car it's hard to get rubber from going into it from a dead stop.
:???: I don't agree at all. Shannon's car is 100% stock... it will light em up anytime.
wake
Post by wake »
the 01 ssei i test drove was bone stock and it spun both of them pretty good thru first and then hooked right before it shifted to second
im with haro on this..if it isnt at least spinning them for 5 feet in a somewhat straight line
theres a problem. :dontknow:
bonnevillain
Post by bonnevillain »
Seconded, all my Bonnevilles (All N/A Series II, with both transmissions) could spin the tires just fine.
seekinhighhp
I'm jealous...all of you all have cars that spin.from a stand still and mine just chirp. I would like to know what I could do to fix this.
99BonnevilleSE
Year and Trim: 1996 SSEi
Post by 99BonnevilleSE »
Wouldn't replacing your differential with a LSD help? I don't know, I'm just throwing that out there. Hopefully somebody will chime in.
I'm backkkkkkkkkkkkkkkkk!
willwren
Post by willwren »
The LSD will make it HARDER to squeal the tires, as they both will have drive traction at the same time. Even in a straight line, and OEM (open) diff equipped car like most on this forum will burn twins, but they don't actually start burning at the same moment. One side lags by half a second, transferring the entire load to one side of the diff during that moment. This is almost as dangerous as burning in a turn.
An LSD won't fix his broken car, either.
yourgrandma
Year and Trim: '02 SSEi
Post by yourgrandma »
If I lock into first an punch it from a 15mph roll I get spin. Silly wrong wheel drive. Lol.
02ssei
Year and Trim: 2002 pontiac bonneville ssei
Post by 02ssei »
pretty bad. you want spin and i'm trying to keep it down to a minimum. spinning the tires is fun sometimes to get some attention. but, i want the push you back in the seat and hold you there kind of take off.
2002 Bonneville SSEI 170K
"Three men walking always has one teacher."
99BonnevilleSE wrote:Wouldn't replacing your differential with a LSD help? I don't know, I'm just throwing that out there. Hopefully somebody will chime in.
Also, the limited LSD's that are available are extremely expensive.
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
seekinhighhp wrote:I'm jealous...all of you all have cars that spin.from a stand still and mine just chirp. I would like to know what I could do to fix this.
Actually starting from a dig is the worst thing you can do.
2003BlackSapphireSLE
Year and Trim: 2003 Pontiac Bonneville SLE
Post by 2003BlackSapphireSLE »
you might just have some really sticky rubber. what kind of tires are you running?
2003 Pontiac Bonneville SLE - Sylvania Silverstar Fog lights, 5000k HID conversion low beams, Disabled DRL, cranking headlight delay kit, GXP style exhaust tips, solid front mount. Approx. 86k miles and still kickin strong!
