Cleaning carpets
bobtaz13
Year and Trim: 2001 SSEi
1991 SE
Cleaning carpets
Post by bobtaz13 »
Any one have any secrets on cleaning and protecting me carpet in Pure Evil. I normaly pressure was them and let them dry for a couple days. Is there something else i should try
2001 SSEi | Galaxy Silver | GenV supercharger P&P | Intense 3.2 MPS | Intense FWI 4"| Custom PCM | TOG Ceramic headers | Magnaflow 3" cat | 180° stat | Aeroforce scan gauge | PRJ plug wires | PRJ fuel rails | Silicone vacuum lines| AP103 plugs | 3.2 MPS | 42.5# injectors | Intense 1x cam kit | YT 1.8 Rockers | 105# springs | Meziere HD pump | N* Tb | 185mm MAF | 2" Phenolic Intercooler | Oil pressure kit | L32 short block | 5% overdrive SFI Balancer | L67 heads custom ported | EBC USR Rotors | EBC Red stuff pads | Custom HID Fog lights, with HI-beam over ride | Polyurethane motor mount | Energy Suspension end links | GXP Shocks/Struts | Custom Drop springs Front, Rear FE5 Springs | GXP Strut tower Brace | GP GXP 18x8 Rims | Polished Exhaust tips | Triple Edge High Performance Street/Strip 4T65E-HD |
Re: Cleaning carpets
I scrub the crap out of them with a small brush, and then finish with a power wash.
enslow
Year and Trim: 97, 99 Lesabre
Post by enslow »
I use a small hand pressure sprayer (a pesticide sprayer, but I bought and dedicated it for this purpose) to spray the carpets with a carpets cleaning solution + deodorizer, or whatever cleaners/stain removers you want. I then vacuum with a wet/dry shop vac. You'd be surprised how black the water is, even after several cleanings.
When you pressure wash, are you doing this inside the car? If so, I'd think that you might get shorts and corrosion on electrical connectors, and mould in the carpet underlay that won't dry even over several days. I'm going to assume you are pressure washing the removable mats.
No, I'm going to assume he removes the whole interior or at least the seats and console, and pulls the carpet out, like what Haro does.
How often do you do this?
enslow
Post by enslow »
00Beast wrote:No, I'm going to assume he removes the whole interior or at least the seats and console, and pulls the carpet out, like what Haro does.
I'd rather play Scrabble. :sadeyz:
bobtaz13
1991 SE
Post by bobtaz13 »
The carpet is all ready out for my stereo install. I have used some citrus degresser on other cars, but worried about the backing on the 00+ carpets. Plus i would like to scotch gard it or something.
I'd use carpet soap and the brush on the top of the can, scrub and wash it, then let it dry next to a heater and some fans.
Grimm
Post by Grimm »
I've got a big bottle of high traffic carpet cleaner from Home Depot that works pretty well. I've got a spray bottle with the cleaner, and another with water. I spray an area with the cleaner, scrub it with a brush, rinse it with the water, and suck it up with the shop vac.
SilverBird92/88
Year and Trim: 1992 Pontiac Bonneville SE
Post by SilverBird92/88 »
I took my carpet's out. The roof used to leak and there would be puddles of water and wet carpet under my seats. So, my solution remove the seats and take the pet out of my car, literlally no carpet. I've been debating on weather or not to use rhino-liner on my floor like the back back of a pickup. Just haven't found the time yet.Image
Uploaded with ImageShack.us
Last edited by SilverBird92/88 on Sat Feb 19, 2011 2:10 am, edited 1 time in total.
SILVERBIRD 1992 Pontiac Bonneville SE.
3800 Tuned Port Injection V6 -135k miles.
Kenwood kdc 50w - Soon to be Double-Din Xplod.
6.5 Kenwood 3way Woofers with Xplod Mobile Crossover Network XS-HF58. Stock Tweeters.
6x9 Kenwood 3way Rear Speakers.
Xplod Full Range xm-405eqx Amplifier
THX Sub
