AC compressor (a must) $700-800?
Sensortrak Struts $450?
Motor mounts/tranny mounts
Radiator 250-300?
Anyone know how much re-wrapping the leather on the seats will cost?
Pisco_Paul wrote:Every time you pat my head, you pat a piece of my valve retainers.
Vince... Lets tackle this one by one..GXP_vince wrote:I am trying to convince my wife to let me spend some money to get the 95 up and running so I can drive it to work and save some money for gas. First of all what is the est MPG on it? <---thats my excuseMy bimmer gets an average of 17.9 mostly highway. This is what I need:
Radiator 250-300?
Here is one of the greatest .gov sites going.http://www.fueleconomy.gov/feg/sbs.htmGXP_vince wrote: First of all what is the est MPG on it? <---thats my excuseMy bimmer gets an average of 17.9 mostly highway.
A/C I was quoted about $750 with labor. I dont know much about an A/C to actually work on them. So I would have someone else do it.Jr's3800 wrote:Vince... Lets tackle this one by one..GXP_vince wrote:I am trying to convince my wife to let me spend some money to get the 95 up and running so I can drive it to work and save some money for gas. First of all what is the est MPG on it? <---thats my excuseMy bimmer gets an average of 17.9 mostly highway. This is what I need:
Radiator 250-300?
Will you be installing the compressor? Maybe you have a friend that can help? A neighbor like Me... Would be a quick swap, with Orifice tube replacement, Drier should be replaced but is not a requirement unless the Warranty for the compressor requires it.. After adding PAG 150 to the new compressor and installing, the system would get pumped down and then recharged to spec..New compressor will run $240-$350 depending on Brand
There are a couple of different struts you can get... Monroe Matic Plus or the Monroe Sensatrack... Again with a Neighbor like me, we'd have that taken care of in a matter of a couple of hours... These struts will run roughly $80 each with Tax
Motor mounts will depend on which ones really need to be replaced
A Radiator can be had for $140-$150 depending on where you buy it from.. And easy to install as well...
It takes about an hour for the first one, then about 35-40 min for the second one, once you know how to do it. You also may want to look into replacing the strut bearings as well. I replaced my struts by themselves, but shortly thereafter the bearings went bad, making that annoying creaking sound when I would turn.GXP_vince wrote:How long does replacing struts take?
I have never done it before.
