Replacing S/C tensioner pulley
dakotapalm
- SSE Member
- Year and Trim: 1994 Pontiac Bonneville SSEi
I apologize if there is another thread about this question, but I tried the search function, and found nothing. How do I remove the pulley of the tensioner on the Supercharger belt? Thank you- I appreciate the help.
1994 Pontiac Bonneville SSEi; CAI; Hood vents; SE grille; LED mirror turn signals; LED running lights (wired to fogs);
Garage:1999 Nissan Maxima SE, stock; 2003 Chevrolet Suburban LS, K&N filtercharger;
- willwren
- Retired Admin
- Year and Trim: .
Re: Replacing S/C tensioner pulley
Loosen it with a 15mm socket.
dakotapalm
- SSE Member
Aha. Now that I replaced it, I feel rather foolish for the question. Seemed there had to be some sort of trick to it, but it was simple as you said.
martynickel
- LE Member
- Year and Trim: 97 SE
It would have been so so so helpful if one of you had mentioned that the bolt is left-hand threaded (before I twisted mine off).
