New Headunit Q
aCiD
Year and Trim: 98 SSEi
New Headunit Q
Post by aCiD »
Yes, that's right, I'm posting an audio question here. What's it to ya?
CD player fried in the Bonne, need something new for when winter rolls around.
Will this guy fit: http://www.kenwood.ca/Car_Entertainment ... ers/DPX303
Also, it advertises "steering wheel input" how do I get that *shoot* hooked up? I'm lazy, busy, and not googling that *shoot* :P
Thanks.
1999 Mustang GT - 600rwhp 520rwtq
2004 G35 M6
2002 Jeep Grand Cherokee Overland Edition
1998 SSEi
1997 SSEi - wrecked
1995 SE - blew up 3 3800s, gave up
viper79
Year and Trim: 2000 Galaxy Silver SE no mods
Re: New Headunit Q
Post by viper79 »
No.
It may fit with modification, but is not recommended. Remember this is a Dock n Lock system. No wires come out of dash, it is a male connection to a ribbon. It's best to look at this one. http://www.crutchfield.com/p_113MP745U/ ... _and_specs.
This is just a radio and looks great. Also, if you want to be safe with your safety features in you Bonnie I HIGHLY recommend this wire harness. PAC C2R-GM32R. Good luck. ;)
aCiD
Re: New Headunit Q
Post by aCiD »
Thanks.
I put one similar to that in a couple weeks ago, made the harness myself and it worked perfectly the first time, so much better than the stock one. Especially since the CD player works now :P
Love Kenwood so much.
2004 G35 M6
1998 SSEi
1997 SSEi - wrecked
petraman
2013 Audi A4 6MT
Location: ............ Granville, Ohio/Erie, PA *WCBF '08 SURVIVOR* *NEBF '07 SURVIVOR*
Re: New Headunit Q
Post by petraman »
A double din install has been done before, and if you're good with fabricating with fiberglass, it's not that bad to do. There's plenty of work space behind the dash. If you decide to do it try to get in contact with randman1. I'm not sure if he's on the forums anymore, but he was the one who did the install
viper79
Re: New Headunit Q
Post by viper79 »
I have tried it. Without modding it does not fit. The DnL male end along with the female causes a space issue. I would love to see the Mod pics.
I wonder if you could mod the unit itself.
- Width 182(mm) 7-3/16(in)
- Height 112mm (4-7/16 in)
- Depth 160mm (6-5/16 in)
I will check this now. I shall be back! I am an audiophile, folks!
viper79
Re: New Headunit Q
Post by viper79 »
viper79 wrote:I have tried it. Without modding it does not fit. The DnL male end along with the female causes a space issue. I would love to see the Mod pics.
I did check this on a 2000 SE and the male DnL connector causes a major problem, UNLESS you can mod the deck or like petraman said. Good Luck. If I am wrong, learn me. I need photo's.
petraman
2013 Audi A4 6MT
Re: New Headunit Q
Post by petraman »
1998 SSEi ;)
The 92-99 Bonnevilles are Din and 1/2. Also, a double din does fit in the 00s as it's been done many times before... Here's a link to the install kit on ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 602_263622
viper79
Re: New Headunit Q
Post by viper79 »
petraman wrote:1998 SSEi ;)
Thank you. I may have to look into this! I think my next HU will be a DD.
Rusgreim
Year and Trim: White 2000 Bonneville SLE
Re: New Headunit Q
Post by Rusgreim »
That kit is NOT going to address the primary issue with the installation of DD head units in the 2000+ cars, that being the low depth clearance. The only way you are fixing that is with a dremal tool and some patience.
Russell (Rus or Rusty)
White 2000 SLE - 161k Miles
Current Mods - Transgo Shift Kit, 180* Drilled Thermostat, NGK TR55 & Belden Plug Wires, Suspension Energy Endlink Upgrade, "Stock" 12-Way Power Seats, "Stock" Heated Seats, "Stock" Homelink GDO, Cleared Corners, Pins & Dealer Badge Removed, 2002 56I Center Console, Dash Trim, Steering Wheel and Shifter Swap, Auto-Dimming RV Mirror, Pioneer AVH-P4000DVD MP3/USB Headunit w/ Steering Wheel Controls and iPhone Music Interface, Hood Protector, Gutted Airbox w/ K&N Filter.
Mods in Progress - SSEi Inflator with Stock controls, Chrome "Swoopies" (Have rims, need tires)
Future Mods - Viper 5701 Remote Start with Smart Start and 35% Window Tinting
swampthing
Re: New Headunit Q
Post by swampthing »
Has anybody noticed that the op has a 98? All this 2000+ talk is pretty much useless.
Current fleet:
aCiD
Re: New Headunit Q
Post by aCiD »
swampthing wrote:Has anybody noticed that the op has a 98? All this 2000+ talk is pretty much useless.
The even more useless part is I said I already installed a new one weeks before even the first reply :P
All good!
2004 G35 M6
1998 SSEi
1997 SSEi - wrecked
viper79
Re: New Headunit Q
Post by viper79 »
So after beating a dead horse, can we establish that you CAN install a DD HU flush with minor modding in a 00+? I really would like to know. Also, I hope that system rocks in your 98! :headbang2:
Re: New Headunit Q
viper, you made a mess of this topic and posted a lot of false information. Yes the 2000+ uses the dock'n'lock, but only 00-01 use the ribbon cable. However the original poster has a 98, so none of this applies.
If you want your own questions answered, start your own topic.
