New member
New to the forum? Introduce yourself here. Been around awhile? Tell us about yourself.
doughboy1338
Year and Trim: 2004 GXP
New member
Post by doughboy1338 »
Hi, my name is David. I work for General Motors, at the Orion Assembly plant, in Orion Township, MI. We used to build the Pontiac Bonnevilles thru around 2004, Buick Park Avenues, Oldsmobile Auroras, and Buick LeSabres. We currently build the Chevy Malibu, and the Pontiac G6. I am a pipefitter, and work in the Paint dept. on third shift.
I recently purchased a 2004 bonneville GXP with about 154,000 miles. It seems to be in pretty good shape so far. I bought it off of e-bay for $6000, so I figured that was a pretty good price. I got a one way ticket to Indianapolis and had the seller pick me up at the bus station, dropped him off at his warehouse and proceeded to drive the car back to Detroit, MI with no problems. In the first week, the passenger side headlight went out and I changed it no problems. Also the driver's side fog light went out. I looked all through the owner's manual and saw nothing about the fog light or what type of bulb it took. Finally found out it took an H-3 but now am having problems figuring out how to replace it.
Driver's side heated seat is not working either. Light will come on but will not stay on. Dealer looked at it and told me it would be almost $800 for whole new heated seat assembly and module. Needless to say I told them that I really didn't need the heated seats. : ) So far everything else seems okay.
bonnevillain
Re: New member
Post by bonnevillain »
Welcome! cool that you worked on the bonnevilles.
The GXP fog lights going out is a common problem, due to a bad ground I think. It's discussed some here: viewtopic.php?f=17&t=11553&hilit=gxp+fog+lights
The heated seats have also been discussed, I had the same problem as you. First check the Fuse, but check this topic out: http://www.pontiacbonnevilleclub.com/fo ... fix#p77854
doughboy1338
Re: New member
Thanks for the info. I will check it out.
Black Pearl
Re: New member
Post by Black Pearl »
Welcome to the forum. Thats cool you used to build the Bonnes. What was it like seeing the last one roll of the line? You did great painting mine.
Bonneville Forum COTM Sept. 09
Pontiac Bonneville Club COTM Dec. 09
doughboy1338
Re: New member
It was really cool working in the plant. I worked on the production line back then in 2000 before I started in my apprenticeship. We stopped making the Bonnevilles in 2004 I think, and then the last of them were made down in Hamtramck, MI down near Detroit at the Poletown plant. They also made Cadillacs at that plant.
Whoever engineered those *dang* fog lights on the GXP should have their ass whooped.
BlackHawk99
Senior Moderator
Senior Moderator
Year and Trim: _
Re: New member
Post by BlackHawk99 »
Welcome from Grand Blanc!
My wife and I have had six Bonnevilles over the years...and now have a GTP.
WhiteArrow3800
Re: New member
Post by WhiteArrow3800 »
Welcome to the Community! :wink:
Re: New member
Post by gonzo4191 »
welcome to the madhouse!
TenGHz
Re: New member
Post by TenGHz »
Welcome aboard! Good to see someone who still builds them in the USA. Keep up the good work.
The fog lights and heated seats are common problems. Someone here should be able to help you fix up your issues!
-Joshua-
