Wow low 13's? What gearing?pontiac6269 wrote:455 engine, turbo 400 transmission and a Oldsmobile 12 bolt with 3.08 gears. Interior was originally dark green but was switched to black before I bought it. The suspension has 2nd gen f-body spindles, rotors, brakes, tubular upper control arms and will be adding a bigger sway bar on the front. The rear control arms will be boxed and a sway bar added. All suspension bushings are polyurathane. 1/2" lowering springs in the rear and 1" in the front. The 455 is in my 62 GP that ran very low 13s in the 1/4 mile at a weight of 4200 pounds with me in it.
Thanks,
Eric
probably around 4000spidey3479 wrote:So how much does a 62 gp weigh by itself? Hmmmm...
