transmission interchange
kaotikd
Year and Trim: 2000 ssei
Post by kaotikd »
I have a 2000 ssei with bad trans. Will a 1997 grand prix gtp trans work in my ssei?
sandrock
Re: transmission interchange
Post by sandrock »
Short answer is no.
Long answer is yes, BUT IIRC there was an electronics update somewhere around 2000, as well as a hardware update. I'm still not up to speed on the 4t65 yet, and I am sure someone that is will better steer you, but my gut tells me it won't quite work.
agrazela
Year and Trim: 04 Lesabre, Stock
98 Lesabre, Retired
Post by agrazela »
Without swapping any internal parts, the only transmissions that are a direct drop-in replacement for a 2000 SSEi are:
2000-2002 Pontiac Bonneville SSEi
1999-2002 Buick Park Avenue Ultra (though the Torque Converter is different)
No Grand Prix GTP (or other W-body) trans will be a drop-in, because they are not Internal Mode Switch (like 2000+ H-Body)
Bone Stock
Retired
kaotikd
Post by kaotikd »
Ok thanks for all the input.
2001SSEi
Year and Trim: 2001 SSEi
Post by 2001SSEi »
I am looking for a spare transmission and I found a 2003 SSEi transmission with low miles, What do need to changed or update or make this work in a 2001 SSEi?
Internal changes or differances? I know it has a updated 4th output shaft.
I also know it may require the 2003 control module, is this different than the PCM or is it part of the PCM/ECM?
2001 SSEi 133,000, Intense FWI, ZZP SS Headers, S1X Cam, ZZP Aluminium Heads, 3.2 Intense, GenV, 180 Stat, 42#, WB O2 LC1, HP Tuner Pro, ZZP tranmission.
I believe the difference in the PCM is all about the trans, although I could be wrong. I know an 03 trans won't work with an older PCM, idk about a newer PCM and trans in an older car.
