Well I replaced the plugs and wires, cleaned the TB and all the sensors thoroughly on my 88 le sabre.
It still had a weird miss which happened occasionally. Sudden throttle bursts would cause a put put put, then normal performance. I guess it was more of a delay than anything.
I headed to the junkyard yesterday to find a Series 1 L27 motor in the "dead motor" part of the junkyard. Found a 94 buick park ave and grabbed the ICM mounting plate, ICM and coils. I tested the coils with a multi-meter and 2 read 5.7 and the other was a 5.8. I forget what ohms setting I was on. Either way, good to go. Popped the new ICM and coils on the car and boom, the car is smoother than my SSEi. Its amazing actually.
Moral of the story. If you have any misfire or weird ignition/performance problems with your 88-91 bonnie or whatever car with the 3.8, try popping in the newer Delco style coils and ICM, it cost me $20 for the whole set. Its so easy to convert it to the new system, all you need is the mounting plate, 15 minutes of time, the bolts, ICM, and the coils.
How to fix surging, missing, misfires, etc on a 88-91 car
wjcollier07
- Year and Trim: ____
Re: How to fix surging, missing, misfires, etc on a 88-91 car
It definitely seems we're lacking the same lot of 87-91s we had..and the ones we do have are mainly owned by people that know everything they need to know...quite unfortunate.
But yes, awesome to be reminded what a simple dump of the magnavox coils can do for a good ole' LN3.
John
wjcollier07 wrote:It definitely seems we're lacking the same lot of 87-91s we had..and the ones we do have are mainly owned by people that know everything they need to know...quite unfortunate.
I agree with this... Forgot to tell you guys I had done the swap on the LE.... Nothing like Type II coils and TR55 plugs in an LN3...lol
Yeah Hans those magnavox systems get to be an issue when the years pile up.. I'll take a guess and say the system was Oozing too?
- Alibi
- Posts like an L27
- Year and Trim: '89 LeSabre T Type
I hate it when the magnavox coils leak out that goo... its such a pain to clean it up. Acetone helps to clean it up though.
On every LN3 that I've owned one of the first things I do is swap in a Delco setup. Its just too easy and it makes the car run a bit better.
-Eric
"Energy and Persistence Conquer all Things" --Benjamin Franklin
-1989 Buick LeSabre T Type: 220k miles
-1987 Fiero GT: 224k miles
-2012 Honda Civic (boring, but its a good DD)
Yeah I love the Type II as well... It just looks right at home and clean with the 93 Wires....lol
dirtracr95
- Posts like an L27
- Year and Trim: 1988 and 1987 Buick Lesabre T-Type
yea my 4 door Lesabre probably needs this swap but it still runs just misses under throttle and i dont drive it anyway. Its not plated or insured.
captainmiller
- Year and Trim: 2005 Pontiac Grand Prix GTP - 205,000 km
I used to drive an '89 SSE. This was the first mod I did. Prior to the swap the thing would crank for 20 seconds before starting if it were cold or raining out. After the swap it started instantaneously every time. Worked amazingly well.
2005 Pontiac Grand Prix GTP Competition Group - 43, 000km - L32 3800 - 3.29 Final Gear Ratio - RETIRED
1996 Pontiac Bonneville SSEi - 203, 000km- L67 3800 - 2.93 Final Gear Ratio - RETIRED
1989 Pontiac Bonneville SSE - 222, 000KM - LN3 3800 - 2.97 Final Gear Ratio - RETIRED
