Remove and Replace headlights
billberry12
- SSE Member
- Year and Trim: 2001 SE 130,000 miles.
I have bought a new set of headlights for my 2001 bonneville SE. Does someone have a simple set of instructions and how to remove and replace them? Is there a diagram somewhere? I hate to mess up trying to do it myself. Any idea how much a shop would charge me to do this?
Thanks for you help.
Bill
Bill
2001 SE
130,000 miles. All but 11,000 are mine.
Want to drive it another 130,000! Any tips are welcome.
- Gumball
- Retired Moderator
- Year and Trim: 2000 SLE
Re: Remove and Replace headlights
its easy, two bolts each. use a 10mm socket. after the screws are out grab hold of the HL and pull straight out.
in doing so on the outside edge you will feel it holding on to something. its a socket with a ball joint.
give it a good yank.
edit: pics and more info found in this thread. http://www.pontiacbonnevilleclub.com/fo ... =14&t=5512
in the first picture of the HL you will see where the two bolts have been removed.
sco99888
- Year and Trim: 2001 se non supercharged
there is plenty of room just turn the light insert counter clock wise and it will unlock,i have big hands got behind there no prob did not have to take light out.
- Gumball
- Retired Moderator
sco99888 wrote:there is plenty of room just turn the light insert counter clock wise and it will unlock,i have big hands got behind there no prob did not have to take light out.
I think your referring to the bulbs, he is replacing the whole headlight.
sco99888
opps sorry i just woke up when i posted that...lol
billberry12
- SSE Member
Anyone know where I can buy just the clear lense's for the headlights, instead of the whole unit, to save money.
Thanks,
Bill
Thanks,
Bill
2001 SE
Nobody sells them like that. You have to buy the entire assembly from GM.
bonnevillain
- Year and Trim: 2002 SLE
or ebay, although the quality is debatable
You can clear the lens yourself. Does somebody have the link on how to do this? I did it myself on my 2000 ssei. Once you get the light assembly out you just have to remove the housing from the lens (being careful about the seal) then you just have to remove the amber lens that is inside. Someone should have the link for this. Sorry I don't.
bonnevillain
he is looking to replace his headlights, not clear the corners.
