winter oil
bonnevillain
winter oil
Post by bonnevillain »
do you guys switch to a thinner oil in winter? I am running 10w-30 right now... should i switch to 5w-30 or 0w-30 next oil change? in my 95 i ran 10-30 year round since it had oil pressure issues.
Mark Fahey
Year and Trim: 2000 SSEi, 3.4", FWI, Saner HD sway bars,137K
Re: winter oil
Post by Mark Fahey »
Go by your manual's recommendations which would be 5w-30 for winter conditions.
2003 SSEi
Year and Trim: 2003 SSEi.
LOTS of Mods
Re: winter oil
Post by 2003 SSEi »
i have never switched oil strictly for winter. Different Climates such as the OP being in MN may dictate it tho
TenGHz
Re: winter oil
Post by TenGHz »
I use 5w-30 in the winter as well.
-Joshua-
Re: winter oil
I run 10w-30 year round because thats what my oil cap says.
EWC88
Year and Trim: 01 Se
Re: winter oil
Post by EWC88 »
harofreak00 wrote:I run 10w-30 year round because thats what my oil cap says.
agree, I never even heard of people switching oils for winter, always thought it wasn't good and just to stick with what the oil cap says
R.I.P 2001 Se :(
Archon
Re: winter oil
Post by Archon »
Your owner's manual will go into greater detail of what oil is recommended at which temperatures.
bonnevillain
Re: winter oil
it gets a lot thicker in the winter. watch your pressure gauge when it gets cold.
i never even thought of the manual :bstooges:
Re: winter oil
Yeah, my cap on the 03 says 5W-30, and that's what i run anyways. (00 cap said 10W-30). Just use a good quality oil and filter, and you will be fine.
Bazza
Year and Trim: 2002 SSEI
Re: winter oil
Post by Bazza »
I run 5w30 or 0W30 full synthetic in mine all winter, as it gets very cold here. -40 is not uncommon.
I will make this really simple.
10 (weight of oil when cold) W 30 (Weight of oil at operating temp.)
5W30 does everything 10W30 does, and a bit more. It circulates better at very cold temps.
Both oils are 30 weight (and identicle viscosity) at operating temp.
Easy experiment. Take a jug of 5W30 & 10W30 place them in your freezer overnight.
(A freezer is about -10C) Then try to pour each of them the next day. You will understand why 5W30 is a good idea in winter.
If you live in a warm climate where it does not dip much below freezing 10W30 is fine. Where I live, You will not start you car on some days with 10W30 in the crankcase as it turns to molasis in -40.
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Re: winter oil
Post by repinS »
Ditto. Oil pressure gauge isn't complaining either.
jseklund
Year and Trim: 2003 Bonneville SSEi
180,000 Miles
Fairly stock.
Re: winter oil
Post by jseklund »
I live in MA and use 5-30 year round. I go with Amsoil's full synthetic and change every 10-12K (which is about every 3 months). I've got over 200K on the car and the only oil related problem I've ever had was the valve cover gaskets going around 150-170K and leaking oil. Replaced gaskets, all set now.
swampthing
Re: winter oil
Post by swampthing »
i use 10-w30 year round but then again it never gets below 20 around here in the coldest winter
Current fleet:
00ssei
2000 SSEi *SOLD*
2000 GP GT *SOLD*
Re: winter oil
Post by 00ssei »
I say stick with with what the oil cap says. If the engineers who built the car recommend 10W-30 then thats what you stick with.
IMO, you shouldnt ever switch oils in your car.
- Zin
*SOLD* 2000 SSEi | Midnight Blue Metallic | 120k
Supercharged decal 3rd brake light | Mostly stock| black leather interior | One of a Kind Tails | Custom SSEi Overlay | Painted Grille | Tints 20%(back) 35%(front)
** NEW PIC's **----->: viewtopic.php?f=9&t=12985
2000Silverbullet
Re: winter oil
Post by 2000Silverbullet »
I would recommend 0W30 for winter temps less than 20F and 10W30 for summer temps over 80F.
Because I don't see either extreme, I use 5W30 as recommended for my oil pressure/volume upgrade.
Re: winter oil
I use 5W-30 all year round. Did in my 2k, and do in my 03. I might switch to 0W-30 in about 3k, when I change the oil after the LIM job to Amsoil.
PRD2BDF
Re: winter oil
Post by PRD2BDF »
When I had my Bonneville, I ran 10W-30 all year round using store-brand synthetic oil
