Any brake pads that don't create alot of dust?!?
RyVa11
Year and Trim: 93 Bonneville SLE
Post by RyVa11 »
Everytime I clean my car real good the front wheels will be black within the week. And you all know how hard it is to begin with to clean the mesh golds. I have tried Oreilly's and AutoZone's. Before I try Napa's does anyone have any suggestions?
Intake, Magnaflow cat, Flowmaster exhaust, clear corners.
Ultra Boost
Year and Trim: 1994 Buick Park Avenue Ultra
Re: Any brake pads that don't create alot of dust?!?
Post by Ultra Boost »
Maybe try Wagner ceramic pads? I think the ceramics create less dust.
Needs more blower whine!
J Wikoff
Year and Trim: 1992 SSE
Post by J Wikoff »
We've got Wagner ceramics on the Grand Am. They make some dust, but not much.
I've had Midas ceramic and now Raybestos Quiet Stop ceramic now and I never saw/see any dust to speak of.
JMH1950
Year and Trim: no longer a Bonneville owner
Post by JMH1950 »
I put ceramic pads on last month and haven't noticed any decrease in dust at all. Not sure what brand they are but I'm not impressed with them.
wjcollier07 wrote:Darn it John...now you got me thinking mine's not big enough.
2001 F150 a basic six cyl with 5 speed manual trans.
'66 Piper Cherokee 360 CID , 180 hp, 155 mph @ 2500 rpm, drop in K&N filter.
RyVa11
Post by RyVa11 »
I have ceramics on it now from AutoZone. The ones I bought from Oreilly's were Semi-Metallic.
adinini
Year and Trim: 99' SLE
Post by adinini »
My Ceramics from Autozone are dust free.
RyVa11
Post by RyVa11 »
They may not be ceramic then, can't remember it's been awhile. Well I will be replacing them with ceramics and see if that will help.
mas
Year and Trim: 1998 Boneville SE
1991 LeSabre Limited
Post by mas »
I just put Wagner Edge on the 98 bonneville and after a short break in period there is hardly any dust on the rims, and they grab real nice too. I should say they are a ceramic pad too so you will need good quality rotors other wise they will get thinned out quicker than usual. I use the Wagner discs too, domestic made good stuff.
I have Wagner Thermal Quiets on the 91 LeSabre. They were what was the new thing a couple years back when I did this car. Upon closer visual inspection they are like the same thing only not laser cut as are the Edge pads. Also are a ceramic. Never had a dust problem.
Any pad that has organic material will dust. If you look at a lot of the brand new fords and stuff you see crazy black rims. Organic pads :> Semi metallic is ok, but they dust up a bit too.
Funny side thinggy... on my mountain bike it has disc brakes and the factory ones were organic. They made so much dust it wasnt funny and were down to nadda in like two weeks. I swapped to some ceramic pads and that was 2yrs ago, no dust and they still are 50%. And I do a lot of downhill as the ski hill here allows mountain bikes in the summer... even let ya hook your bike onto the chair lift.
1998 Bonneville SE, Silver Mist metallic, factory 16" chrome t-stars
- PLIM, PLOG, Belden blues, TR-55s, 180 stat, gutted and insulated airbox, FE2 rear sway, Moog endlinks and bushings,
new UIM and gaskets, DEXFree, Nokian i3 225/60/16, Blazer projector fogs, dual trans coolers
1991 Buick LeSabre Limited, Medium Garnet Red metallic, Chev Eurosport 3.1 Z28 16" rims
- PLIM, PEMs, no CAT, no resonator, Delco coil swap, Belden blues, TR-55s, 180 stat, rice pipe FWI, FE2 rear sway,
Moog endlinks and bushings, Michelin Pilot 225/55/16's, dual trans coolers
wjcollier07
Year and Trim: ____
Post by wjcollier07 »
Bendix CT-3 Ceramic
John
mike2fix
2000 SSEi
Post by mike2fix »
Akebono Premium Ceramic from RockAuto.
I have installed several sets on different year Bonnevilles, no dust to speak of.
freneticburn
Year and Trim: 1998 Bonneville SE?
Post by freneticburn »
mike2fix wrote:Akebono Premium Ceramic from RockAuto.
are they quiet?
