Heads Up Display with New Sunglasses
J-ROD
Year and Trim: 2012 Chevy Silverado Z-71 LTZ
Post by J-ROD »
My sunglasses broke today, so I went to Wal-Mart and purchased a new pair of Panama Jacks. Now I can't see the heads up display with them on if the sun is shining. Any thoughts. I didn't have any issues with my old shades.
Jarod S Fisher
2009 Chevy Impala LTZ
GoldenBullet
Year and Trim: 2001 GMC Yukon XL
Re: Heads Up Display with New Sunglasses
Post by GoldenBullet »
your new sunglasses are polarized, which means they reduce glare, which essential is what HUD is, i had the same problem and had to switch to a different pair
-Matt
lglarum
Post by lglarum »
Agreed with GoldenBullet. I can't see my HUD very well at all with my Native's which are polarized, but I can see it with my non-polarized oakleys.
donky4444
Year and Trim: 2011Taurus SHO
Post by donky4444 »
I have the same problem. My sunglasses are prescription and polarized so it's not like I can go out and get new ones. I just deal with it and use my GPS for my speed.
2011 Ford Taurus SHO, Livernois Motorsports Stage 4x+ tune, 3 bar MAP sensor, Motorcraft SP534 plugs, 160* Tstat, best ET 12.5612@ 108.96 MPH running 0.75 gallons of E85 to 13 gallons of 93 octane, 35% tint, 2013+ fender badges! debadged trunk and rear quarter window
2008 Grand Prix GXP Dark Red, Magnaglow Cat Back, Overkill Motorsports Tune, K&N FWI, 20% tint, 6,000K HID lows, 5,000K HID fogs and HIR highs (sold)
2005 Greystone Metallic, cleared corners, 20% tint, drop in K&N filter with gutted air box, 6000k HID low beams and fog lights, LED interior lights and reverse lights (sold)
J-ROD
Post by J-ROD »
Ok, now that we know the cause of it, is there anything that can be done to fix it other than getting different sunglasses? Would placing a small piece of tint in that area make a difference at all? Any thoughts?
Jarod S Fisher
imidazol97
Post by imidazol97 »
J-ROD wrote:Ok, now that we know the cause of it, is there anything that can be done to fix it other than getting different sunglasses? Would placing a small piece of tint in that area make a difference at all? Any thoughts?
No.
The polarized sunglasses block light that is not oscillating in a vertical mode. The light reflected off highways, water, and other surfaces are mostly oscillating in the horizontal component. Therefore the sunglasses block a lot of the bright light, glare, reflected in that way.
But the light bouncing off the shiny surface of the windshield coating is the horizontally polarized light. Therefore the sunglasses block them. If the glasses block light reflected from a highway, it will block the light from the numeral display of our HUD (I have one on my Buick--love it).
pete25
Year and Trim: 2003 Pontiac Bonneville SSEi
Post by pete25 »
yep, polarized sunglasses do that. i found that out the hard way. 200 dollar oakleys and first time i wear them i cant see the hud. i too was disapointed.
HurstGN
Recognized Vendor
Recognized Vendor
Post by HurstGN »
Depends on the glasses. I used to wear Serengeti Drivers, polarized, and it cut the glare of the dash, but I could still see the HUD. It was ever so slightly dimmer, but I could see it. Step up to a new set of 7EYE Diablo's with the NXT lenses, and polarized...and they're doing the same as the Serengeti's. I can see the HUD, but the rest of the dash refelctions are cut. The first 7EYE's I got had non-polarized lenses and I couldn't even imagine driving with them. Way too much glare for me. I definitely need polarized for driving, and can still see the HUD.
The Serengeti's are cheaper (about $90), the 7EYE's are expensive ($250)
Dan McCann
2000 SSEi
willwren
Post by willwren »
Tilt your head to the right or left, or hold your sunglasses in front of you rotated 90°. Your HUD will come back into view.
It's not just the fact that they ARE polarized, it's what ANGLE the polarization is at. My Maui Jim's also fade my HUD by about 75%. But I don't drive that car much and just deal with it.
GXP_vince
Year and Trim: WCBF 2008 Survivor
Post by GXP_vince »
Maui Jim's FTW. There is no way around it just deal with it or get non-polorized sunglasses. I could not live without my Polorized Maui's. I am from FL on the Gulf of Mexico and from my fishing days, polorized sunglasses proved themself to me many of times, they saved my ace many times because I saw the flat (grass or sand flat in the water) before I hit them.
f1.4 and be there ----> http://www.fallbrookstudios.com
95 Black Bonneville SLE Supercharged / 95 Green SE, Daily Driver / 95 Black BMW 740iL / 06 Jeep Wrangler 3 inch lift 33in Tires / 2005 Tricoat GXP 32k / 2004 GXP *in car heaven*.
