KR elimination Volume 2 (2000 SSEi)
Allmachtige
Year and Trim: 2009 G8 GT
Re: KR elimination Volume 2 (2000 SSEi)
Post by Allmachtige »
99ssei wrote:I'd leave the good sections alone, but I'm a newbie to tuning as well. Are you planning on using Eddie's Table Modifier for your MAF calibration? What are your most recent LTFTs ? It only took me 4 or 5 tries to nail down the VE table.
What do you mean "good sections"? Do you mean only smooth the area around the cell adjustments? If so that would be the 2nd (middle) table I posted above.
2009 G8 GT - White Hot
415/391
99ssei
Post by 99ssei »
You can smooth the whole graph. It may change some numbers that are good values, but not by much. It shouldn't destroy all the work you've done thus far. I always smoothed the whole graph, but if you have a huge section that's perfect, I'd try to only smooth out the areas of concern. Either way, you should be fine.
Allmachtige
Good enough? ...
This is another scan from the drive home after work. I think I'll do one or two more tomorrow morning just to make sure the kinks are out, but for the most part I think this is where I'll start MAF tuning.
415/391
superchargedSSEi
Year and Trim: 1996 SSEi
Post by superchargedSSEi »
Close. Probably only one more revision is needed to get those positive LTFTs to turn slightly negative (or zero if you're lucky), and then you'll be ready for the MAF tune.
Aaron
1996 SSEi (year confused and on the road again at last) : swapped 4T65, cammed and intercooled among other things
Best ET: 13.208
Best trap: 104.96mph
Allmachtige
Yeah I tried to do another scan last night after another 50% revision of what you see above and OMG the numbers were +8.
I wasn't doing a serious test, just me and a friend going to get some dinner, but it was pretty cool last night and I usually do my tests at dusk when its still 70ish out.
415/391
99ssei
Post by 99ssei »
Mine looked like your last graph and I moved on. I think you should be fine with what you got.
Allmachtige
HELP! I've tried running Eddie's Table Modifier Thingy as well as the ScanFormater excel macro tool, both fail.
The ScanFormater gives me a run time error and Eddie's Table Modifier just doesn't plain work (can't see any of my data).
Someone PLEASE run these files through any tool you have that works:
CSV:
http://ente.got-game.org/hptuners/MAF_sept20_01.csv
MAF and IFR tables:
http://ente.got-game.org/hptuners/IFR_01.txt
http://ente.got-game.org/hptuners/MAR_01.txt
415/391
superchargedSSEi
I've never been able to get a .csv exported from an HPT scan to work with Eddie's program. Even if you remove the headers from the top of the excel file and are able get the data to show up, the program thinks that the frame ID numbers are the FTCs so you can't filter the data right. I tried making a new table anyways to see what would happen and that didn't come out right either. It kind of sucks for you HPT guys since Eddie's program makes table editing almost idiot proof.
I'll try running the scan through some old excel spreadsheets I have and see how that goes. They won't care what the order of the data columns in the .csv are.
Edit: All of my spreadsheets are working perfectly. They're a little more labor intensive than an actual program, but they still get the job done and don't involve more than basic copy and pasting. Let me know if you want them.
Last edited by superchargedSSEi on Sat Sep 20, 2008 6:05 pm, edited 1 time in total.
Aaron
Best ET: 13.208
Foghorn
Year and Trim: 1997 SSEi 40th Anniversary
13.07 @ 106.5
Post by Foghorn »
You'll need Eddie's Table Modifier V6.5 to import HPT csv files.
Mapex's MAF modifier Excel file works well, it's more work but gives very good results.
Cheers,
superchargedSSEi
Just installed V6.7 of Eddie's program and it works great...it's nice being able to read the HPT files now. Thanks for the tip Foghorn.
Edit: Suppose a link would be nice for those searching for the program.
http://theblattners.com/projects/tablem ... fault.html
Last edited by superchargedSSEi on Sun Sep 21, 2008 8:34 am, edited 1 time in total.
Aaron
Best ET: 13.208
Allmachtige
Yeah I found a version of Eddie's that worked shortly after I posted this, sorry I didn't reply.
Its strange because the program adjusts my MAF up until I hit PE, then it doesn't make any adjustments of course. So...what do I do about 7500+Hz? Is this something I worry about later with O2 tuning? I ask this because right now my MAF curve is being changed in a way where it slopes up, then goes flat until it reaches the old slope in the higher area of the graph (WOT/PE frequencies).
415/391
Allmachtige
Here this is what I'm talking about:
That's my adjusted MAF (using Eddie's program) after this scan:
http://ente.got-game.org/hptuners/MAF_sept21_03.csv
http://ente.got-game.org/hptuners/MAF_sept21_03.hpl
Should I be clicking the "smooth" button or do I never adjust my MAF above 7500Hz?
415/391
superchargedSSEi
I wouldn't worry about it. The average LTFTs in the area around the bump were 5.5 > 4.3 > 2 > .4 > .1, so the bump itself is probably just an over correction for those higher averages. See what happens after the next scan, it should fix itself during the next adjustment since from the looks of it the averages will be negative in those cells next time around. You can smooth it out now if you'd like though...won't hurt anything.
Edit: What percentage of the fuel trims are you using for the adjustments?
Last edited by superchargedSSEi on Sun Sep 21, 2008 11:03 pm, edited 1 time in total.
Aaron
Best ET: 13.208
Allmachtige
superchargedSSEi wrote:I wouldn't worry about it. The average LTFTs in the area around the bump were 5.5 > 4.3 > 2 > .4 > .1, so the bump itself is probably just an over correction for those higher averages. See what happens after the next scan, it should fix itself during the next adjustment since from the looks of it the averages will be negative in those cells next time around. You can smooth it out now if you'd like though...won't hurt anything.
That was my 3rd adjustment using Eddie's program, that's why I'm a little concerned because each adjustment ignores 7500+. I'll do another scan this evening and I think I'll try smoothing it a bit.
I'm using the default 50% of the fuel trims for adjustments.
EDIT: A secondary concern is that when I smooth the graph is requires numerous clicks of the "smooth" button, which in turn raises just about every cell (richer). I fear this could put me too rich and I'm trying to be as cautious as possible.
415/391
superchargedSSEi
Ah, thought it was the first revision using the program. The O2s are a bit light while in PE so I agree that the 7500+ portion of the table could be bumped up a bit to smooth things out, though I might wait to do it until after the MAF is calibrated. Avoid playing around with the MAF cells around the PE trip point if you smooth things out though, since changing those might have an affect on the WOT LTFT.
Aaron
Best ET: 13.208
Allmachtige
So get everything below 7500Hz all set, THEN worry about smoothing the graph? Or smooth after the O2's are fixed?
415/391
superchargedSSEi
Either/or would work, as long as the LTFTs are fixed before hand. Smoothing the transition before the O2s are fixed would probably give you a bit of a head start on that portion of the tune though.
Aaron
Best ET: 13.208
Allmachtige
superchargedSSEi wrote:Either/or would work, as long as the LTFTs are fixed before hand. Smoothing the transition before the O2s are fixed would probably give you a bit of a head start on that portion of the tune though.
Smooth entire or just the transition from 7500 to WOT/PE? I'm guessing the entire graph, but many times. :wink:
415/391
99ssei
Post by 99ssei »
When I did mine, we just smoothed the section (like 3 cells left and 3 cells right of the drop). If you do the entire graph, you'll throw off some of the numbers you've already found to be good. For now, you should focus on getting your below 7500 hz table stabilized. As mentioned before, the WOT MAF will be calibrated later.
superchargedSSEi
99ssei wrote:When I did mine, we just smoothed the section (like 3 cells left and 3 cells right of the drop). If you do the entire graph, you'll throw off some of the numbers you've already found to be good. For now, you should focus on getting your below 7500 hz table stabilized. As mentioned before, the WOT MAF will be calibrated later.
Agreed. The rest of the curve looks good so I doubt smoothing the entire graph will have much of an impact on fuel trims, but the transition area is so important to the PE/WOT LTFT (and such a sloppy area of the curve) that it should be treated as it's own section imo.
Aaron
Best ET: 13.208
