New 2001 SSEi, Upgrade List - What am I missing
bobtaz13
Year and Trim: 2001 SSEi
1991 SE
Post by bobtaz13 »
I just got my 4th Bonneville and looking at getting a little more performance out of her.
The goals are
1. MORE POWER :twisted:
2. Make it breathe better
3. Not affect the reliability or improve it
4. Budget is not a really problem
This is what I came up with as a good start, but I don’t what to over look anything.
Intense Level 1 Performance Package
AeroForce Interceptor Scan Gauge
MSD Ignition Coils
MSD Plug Wires
Fuel Filter
Optima Battery (red top)
GXP strut-bar
Rear strut-bar - custom?
energy suspension end links F/R
Magnaflow catalytic converter
Should be coming home to the states soon, after 6 years over seas, so want to get this together in the next month or two. Any input is welcome.
2001 SSEi | Galaxy Silver | GenV supercharger P&P | Intense 3.2 MPS | Intense FWI 4"| Custom PCM | TOG Ceramic headers | Magnaflow 3" cat | 180° stat | Aeroforce scan gauge | PRJ plug wires | PRJ fuel rails | Silicone vacuum lines| AP103 plugs | 3.2 MPS | 42.5# injectors | Intense 1x cam kit | YT 1.8 Rockers | 105# springs | Meziere HD pump | N* Tb | 185mm MAF | 2" Phenolic Intercooler | Oil pressure kit | L32 short block | 5% overdrive SFI Balancer | L67 heads custom ported | EBC USR Rotors | EBC Red stuff pads | Custom HID Fog lights, with HI-beam over ride | Polyurethane motor mount | Energy Suspension end links | GXP Shocks/Struts | Custom Drop springs Front, Rear FE5 Springs | GXP Strut tower Brace | GP GXP 18x8 Rims | Polished Exhaust tips | Triple Edge High Performance Street/Strip 4T65E-HD |
freneticburn
Year and Trim: 1998 Bonneville SE?
Re: New 2001 SSEi, Upgrade List - What am I missing
Post by freneticburn »
get a smaller pulley. that may effect some reliability but get nice gains out of it.
willwren
Post by willwren »
The level 1 package includes an MPS with a 3.4".
Ditch the MSD coils and wires. They won't gain you much over what you have. Not worth the time or money unless you have a bad coil.
superchargedSSEi
Year and Trim: 1996 SSEi
Post by superchargedSSEi »
Toss a downpipe on that list, it's a good insurance policy against KR on lightly modded motors.
Aaron
1996 SSEi (year confused and on the road again at last) : swapped 4T65, cammed and intercooled among other things
Best ET: 13.208
Best trap: 104.96mph
2003 SSEi
Year and Trim: 2003 SSEi.
LOTS of Mods
Post by 2003 SSEi »
you cannot run a Optima with a 00+
there is no need for a rear strut bar made for the 00+'s
lglarum
Post by lglarum »
Budget not a problem? SLP headers? That would make it an easier switch to the 3.4" pulley due to possible KR issues. That's the only thing that's keeping me from putting my 3.4" on.
willwren
Post by willwren »
A hogan 3" downpipe might just do it for you on stock exhaust manifolds.
bobtaz13
1991 SE
Post by bobtaz13 »
I was going to hold off on the exhaust (exept the cat) until get the Intense Stage 1X 3800 Cam Package or the Stage 2 3800 Heads & Cam Package. But if a 3" downpipe is a good way to go then i will add it to the list. As for the MSD coils and wires I want them for appearance. Thanks for the great input guys, keep it coming.
As for the budget I have a bunch of my ex-wife’s stuff that will be going on ebay. :wink:
juniorcruzer
Year and Trim: 2001 SSEI black
Post by juniorcruzer »
Nothing like sticking it to the ex!
It hurts reliability if not used properly or allot, but if you want the occasional burst of power, could stick a small shot of nitrous in it.
Or another way to add a larger pulley, alcohol injection. Devils own has some nice kits
Jon
2001 SSEI Black, stock but not for long
bobtaz13
1991 SE
Post by bobtaz13 »
If i got the Hogan Performance H-Body 3" Stainless Steel Downpipe with Hi Flow Catalytic Converter, i should be able to reuse it with what ever headers i get. Right? Of cource there will be welding, but i have that covered.
BillBoost37
Year and Trim: 00 Regal
Post by BillBoost37 »
Remember to have the cat code programmed out on the pcm or that magnaflow will probably set a low efficiency code. For some reason the 00+'s suffer from this and the pre 2000's don't.
97 Ei
97 GS
98 GS
2003 SSEi
LOTS of Mods
Post by 2003 SSEi »
bobtaz13 wrote:If i got the Hogan Performance H-Body 3" Stainless Steel Downpipe with Hi Flow Catalytic Converter, i should be able to reuse it with what ever headers i get. Right? Of cource there will be welding, but i have that covered.
you will not be able to use the DP when you get headers
bobtaz13
1991 SE
Post by bobtaz13 »
So would I be better off waiting or is it worth it in the mean time to get the downpine and cat togethe, or should I just get the cat for now.
