1993 bonneville/trans sport alternator to 1990 bonneville?
Karpov
Year and Trim: 3800 1990
Post by Karpov »
What are differences? Only + wire mount?
I have broken alternator on my 1990 and my friend has 1993 trans sport (3.8 v6) alternator but its on miles away so will someone know will that fit?
Same alternator which fits trans sport fits same age bonneville
Karpov
Re: 1993 bonneville/trans sport alternator to 1990 bonnevil
Post by Karpov »
Its 140a model but im happy to know will it fit or will 105a model on newer models fit.
95naSTA
Post by 95naSTA »
It's not looking like it's a direct swap:
Karpov
Post by Karpov »
95naSTA wrote:It's not looking like it's a direct swap:
Seems like attachments are reversed, but if those are same size, you just turn alternator another way?
Only problem is, is there enough room for fatter 140a alterntor and is belt routing in same distance. I mean is measure same pulley top to alternatoe case.
Its possible to turn alternator bottom in another side if + wire connection is too low.
I wonder basic 105a newer alternator is easy to fit but bigger 140 :dontknow:
95naSTA
Post by 95naSTA »
Honestly, without trying it, I doubt you'll know for sure one way or another.
96 SSEi
Post by 96 SSEi »
you gotta make sure the mount positions are the same take good pictures + measure: you can always make your own bracket for mount.
you can always have your own alternator refurbished.
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
MattStrike
Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
'92 Trofeo
Post by MattStrike »
I know I'm late to the party here...
Yes, the 93 alternator will physically fit, but some modifications are needed. In addition to mounting reversed, the orientation of the output stud (as well the angle and tab on the big wire) are different and need to be modified.
I had one on my '89 Lesabre for a while, not bolt in but can be made to work.
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
Karpov
Post by Karpov »
I got it and it places fine even + wirr bolt but engine harness is stuck on bottom.
So alternator wont touch smaller bolt hole.
Longer belt or harness with new location will help.
MattStrike
'04 Dirtymax
'97 Camaro
'92 Trofeo
I vaguely recall pushing some wires out of the way. It was a while back, so I couldn't tell you if I had to un-tape the loom or what I did to get around that. I think it's the harness that went down to the crank/cam sensors.
Boost addict
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
