Moog tie rod question
Merrillspontiac
Year and Trim: 2000 Pontiac Bonneville SE
Post by Merrillspontiac »
I just purchased a Moog outer tie rod for my 00 SE and I am rather confused as to where the washer that was included goes. Has anyone installed this part on their car? Thanks
1997 Oldsmobile Eighty Eight LS
1993 Buick Regal GS Coupe
1992 Buick Regal Limited Coupe
maxi426
Year and Trim: 2003 SSEi
1999 Park Ave. Ultra L67
Re: Moog tie rod question
Post by maxi426 »
I believe it's optional. Use it under the castle nut if you find that the nut goes down the stud too far that the cotter pin doesn't pas through the "slots" in the nut.
Kersh
2005 Bonneville GXP *Sold*
Post by Kersh »
Just installed a set of these myself and can CONFIRM what "maxi426 " said. If the castle nut tightens to a depth that the cotter pin isn't able to engage the cogs in the nut, that can be bad. The Washer is there to take up add'l space.
2006 Saab 9-7x 5.3i
2005 Pontiac Bonneville GXP / 4.6L Northstar *Sold*
2001 Olds Aurora 4.0 w/GXP Exhaust and High-flow cat (OSV Wannabe) *Sold*
2001 Pontiac Bonneville SSEi, 3.4" MPS, Intense Tune, SD headers, high-flow Cat, GXP exhaust, Modified Air Intake, 180* thermostat, GXP: 18" GXP wheels w/255/45/18 tires, CF Trim, Brakes and Strut Tower Brace. SOON TO HAVE: GXP Swaybars.
1972 Olds Cutlass Convertible / 461ci Olds / TH400 / 3.08 Posi. 13.62 @ 99.7 MPH......Got torque?
Yes, I seem to be drawn to GM's orphaned cars......
