Headlights
motoroil34
- LE Member
- Year and Trim: 2004 Pontiac bonneville
Headlights
Just curious if anyone has ever gotten all lights, high, low beams and fog lights all with the flip of the high beam switch and if so how did you do it? I do a lot of night driving so any light I can get would be better.
I just posted this but cant seem to find it again sorry for any doubling up.
Oldman
- Year and Trim: 2001 SSEi
Re: Headlights
There's a little box you can buy online that will make your bright lights and regular lights come on when you turn bright lights on. I've bought one before. I think it's just called a head light control box. I found it on Amazon. Basically it plugs in between your wiring and the headlight on each side. I'm sure they're still out there online somewhere.
dougtoth
2005SLE PEARL
Re: Headlights
Speaking of head lights why do the fog lights go off when you hit your brights?
- MattStrike
- Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
Re: Headlights
Because certain states think it's illegal to have more than a certain number of forward facing lights (which is irrelevant, just look at modern LED fixtures, just another example of how government is failing).
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
- CMNTMXR57
Re: Headlights
Exactly, a certain candlepower limit, which is why, unless you have factory HID's, that both your lows and fogs go off when the high beams are activated.
THat aftermarket relay will work. I've used it in several GM trucks over the years, but anyone with a wiring diagram can probably bypass the factory relay.
Daily Drivers:
2011 Camaro SS
Oldman
Re: Headlights
I've tried wiring them, but maybe i'm just not electrically advanced enough to do it. The standard hi/lo switch simply transfers power from one wire to the other. If you make both come on for hi beams, they both come on for low beams too.
dougtoth
2005SLE PEARL
Re: Headlights
Thank you for your responses.
I now feel a lot better knowing that the government has everything under control.
Now if they could just work on the taxes,deficit,economy,crime.roads and bridges everything should be great.
Also maybe they can do something about all the commercials on NFL games.
The time of the game could go from 3:45 to 3:00.
- CMNTMXR57
Re: Headlights
Hey, they're saving us from ourselves, so America, keep the democrat train rolling. Not to take this off base into a political debate as that is against rules.
Daily Drivers:
2011 Camaro SS
- MattStrike
'04 Dirtymax
'97 Camaro
Re: Headlights
If that box doesn't add a dedicated power line for the lights, you'll need to rethink the power supply. I've melted the brights switch on my other car when I had it running all 4 headlamps at once.
Boost addict
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
- Archon
Re: Headlights
On the 2000s, all four lights are lit when the highs are activated. This techinfo post was written based upon that. It's a simple circuit that uses the factory wiring for the lighting. It just provides a ground for the fog lamp relay that is normally removed when the highs are activated. It's not "pretty", but it does the job without a lot of wiring work.
http://www.pontiacbonnevilleclub.com/fo ... c7329.html
Oldman
Re: Headlights
Toggle switches! Everybody needs a few toggle switches lined up on their dash! Get the fancy ones that flip open and look like NOS switches. You can do anything with enough toggle switches!
- unclebubbaSE
- Year and Trim: 2004 SE...graystone, 1SC pkg., spoiler, chromies.
Re: Headlights
Sorry, couldn't resist...The power and control "Democratic Train" has seemed to hit the wall (no pun intended), and derailed a long time ago!.
1oldman
Re: Headlights
Way off topic, a democracy is mob rule. Read the history of ancient democratic Greece to learn what I mean by that. - BC
