3800 Series 2 spark plug torque specs
Merrillspontiac
- Year and Trim: 2000 Pontiac Bonneville SE
I've done spark plugs several times on the 3800's but I have always wondered what is the factory torque specification?
1997 Oldsmobile Eighty Eight LS
1993 Buick Regal GS Coupe
1992 Buick Regal Limited Coupe
ddalder
Re: 3800 Series 2 spark plug torque specs
15 N.m
ddalder
Or if you want that in imperial, 11 lb-ft.
Merrillspontiac
Thank you very much!
94SilverSSEi
- Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi - Location: Racine, Wisconsin
I always use the "good enough" torque spec spin them all the way down and then a little turn till they get tight with the 3/8 ratchet.
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
mhfromphila
- Year and Trim: 1993 SE
When I was in automotive school, they taught us that if you torqued to spec.the plugs would last longer. Never tested it to see if it's true.
1993 SE mag.cat., K&N CAI, B&M drain plug, MSD wires, Energy Suspension end links, Monroe sensotracks,3.06gears,F41,N10,adj.modulator,180 degree stat. SilverStar Ultra highs and lows,TR55 plugs,DEX VI,front trans mount mod.
