Which years are the best?
- willwren
- Retired Admin
Re: Which years are the best?
For long-term reliability of the drivetrain, the Series 1 has shown it's best colors time and again amongst our members. It's a little more basic and robust in design, and doesn't have the complication of DEX issues unless someone really screwed up.
If you want ease of maintenance, get a 92/93 SSEi or SE/SLE/SSE. The OBD1 PCM doesn't require a scantool to diagnose codes, and it's a much simpler design to work on.
Other than that, everyone here is going to post their own PERSONAL preferences based on what they own/drive.
- putertopia
- Posts like an L36
- Year and Trim: 1997 Pontiac Bonneville SE (H4U)
So... my 4t60 has an e on the end, even though line pressure is controlled through vacuum modulator?Jr's3800 wrote:LeSabreUltra wrote:Interesting. I assumed 97 as well because my 97 LeSabre has the 4T60E.Boreas wrote: The 1996 is the only year that has Series 2 and 4t60. However 96 is my favorite year for the same reasons you describe. You get the best engine with the strongest transmission from the factory.
For 97, If you were NA you got the 4T60-E... If you were Supercharged you got the 4T65-E
- Josh
1994 Bonneville SSEi - 136k mi - FWI, 180* T-stat, Fresh upper gaskets
1997 Bonneville SE - 110k mi - H4U, 3.06:1, Tinted Tails, Bridgestone Potenza G009 225/60/16s
Performance: INTENSE PCM, INTENSE 180* T-stat, Gutted air box, K&N air filter, Ported LIM, Borg Warner Wires, NGK TR-55 Plugs, Adjustable Trans Modulator.
Bells and Whistles: Flowmaster 80 crossflow muffler w/ quad tips, 2x Kicker CVR12 Subs in vented box, 1000W RMS 1-ohm American Bass Amp, Alpine MRP-F200 4-channel amp (temporary), Infinity 60.7CS 6.5" Component System (front), Blaupunkt 3-way 6x9s (rear), Pioneer DEH-P6900UB Head Unit, Hardwired Whistler Pro 58 Radar Detector, Hardwired Navigon 2100 GPS
- John Deere Boy
- Retired Moderator
- Year and Trim: 1993 SSE
Member since Nov 2003 - Location: Centerville, IN
I think it's easier to look at the disadvantages of each year or model. These are just things that came to my mind at the moment.
92 - EGR-less L27s are more prone to problems
92&93 - A/C will eventually need converted to R134-a
94 - Hybrid PCM. First year for ECC without driver accessible self diagnostics. No more scanner-free DTC's either.
95 - First year for the L36 with intake manifold problems.
2000(+) - Hood herpes, half shaft failures, window actuator failures
Ol' Timer
- Year and Trim: 1991 Olds 88
- Location: New Jersey - Most of Our Elected Officials Have Not Been Indicted
x2willwren wrote:For long-term reliability of the drivetrain, the Series 1 has shown it's best colors time and again amongst our members. It's a little more basic and robust in design, and doesn't have the complication of DEX issues unless someone really screwed up.
2006 Salsa Vibe - Auto - Side Curtain Air Bags - ABS - Vehicle Stability Control - Tunes No Moon - Monotone - Preferred Package - Slate Cyper Cloth - Steelie Wheels
2002 Snap Orange Beetle - Auto - Turbo
1991 Dark Garnet Red Oldsmobile 88 - Donated to Science
wjcollier07
- Year and Trim: ____
I'm gonna vote for the 87-91s. Both the LG3 and the LN3 were insanely reliable. I personally drove on quite a few occasions an 87 LE with 396k, and my friend finally got rid of it because a rear brake line rusted through. Most of the car was rust, so he just said, screw it, but amazingly, someone else put it to service, and I saw it driving around for another year and a half, when it finally fell off the grid in 2007. Original engine, original transmission. Not exactly well maintained either. Another case, another friend, Blue 89 LE, has currently 410k, original engine, original transmission. He reports the transmission is finally getting a little loose...but the engine still runs SO well, its scary, I know, I've listened to it, its quiet and smooth. Next case is my 89 LE, rust finally made me get rid of it, but at 150k, after very ill maintenance, sitting outside for over 3 years not being driven, being run without a thermostat for about 10k, it reached me. I then put a thermostat in it, and it ran at 215 degrees at full operating temp for over a year...then the radiator finally kicked it, and it overheated, BADLY. That killed the MAF sensor. I had all the nonsense taken care of by 127k. Thats when it finally got driven with real maintenance. It got its transmission flushed once and the fluid changed 3 times, and even at 155k, when it got sold, that transmission shifted TIGHT.
Great car.
Common problems that I know of...cam magnet falling out, MAF sensor dying, crank sensor dying, and of course, bad oil pressure sending units :D There are a few other problems, usually with the EGR or pulling up a QDM code. Or of course, the crappy Teves ABS, but that's not really a reliability issue...that's just a PITA.
And then, next on the list, the LN3's younger brother, the L27. Few more problems it seems. Mine needed an EGR and cam sensor before I got it...and afterwards, it had its plastic LIM coolant port break, but luckily it was a mile from home and was replaced with a metal one.
Another pretty outstanding engine though.
As for the Series II...uhh..sorry...no takers here.
Great car.
John
mrbear3800
- Year and Trim: 2003 Buick Lesabre Custom
QDM? Is that the quad driver code? I used to get that in my 89 every once in awhile. Never was able to figure out why. Never happened in my 90, though. The 90 DID have that god awfull Teves II ABS system. I had to replace the splitter at the rear of the car and it was $100 bucks at the dealer!!wjcollier07 wrote:There are a few other problems, usually with the EGR or pulling up a QDM code. Or of course, the crappy Teves ABS, but that's not really a reliability issue...that's just a PITA.
2003 Buick Lesabre Custom (parents car)
1995 Mercury Grand Marquis (mine)
I don't currently own a GM product
Bonneville92V688
- Year and Trim: ‘12 Jeep Grand Cherokee Overland Summit
92-95 SSE/SSEi FTW.
By far the best looking SSE/SSEi made, 88-91 SSEs after that, then 96-99 SSE/SSEis.
I love opinionated topics like this. Everyone has a different response.
1996 Thunderbird LX - 3.8
- gonzo4191
- Year and Trim: 91 S10 P/U
97 SSEI- 136k - Location: round lake beach, IL
65 bonneville are the best in every category
- firebuick
- Posts like an L36
- Year and Trim: buick allure 2007
NEBF07 ONBF07 ONBF08 - Location: montreal
the 95 n/a also got the L36 and the 4t60
also if you don't whant to mod youre car go L27 but the serie 2 is easy to mod lots of parts
buick regal ls 2002 L36 Buick regal 1983 357 sbc ,2003 Buick park avenue ultra
modkn4750,CAI,er rockers,powerlog,2.5 downpipe,high flow cat,dynomax muffler,hv3,ported LIM,autolite 104,waterpump u/d pulley,180 stat,aeroforce scan gauge,etx mag 17x7.5,245-45-17 flaken ze 912,
pb 14.97@92.77mph 2007 pb 2008 95.45 mph
don
94SilverSSEi
- Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi - Location: Racine, Wisconsin
I dont really know all that much about working on cars so probably will not be doing very much modding if any but are there any mods or rather preventative maintence issues that should be taken care of right away and how hard would any of these things be for a newbie
Once again it looks like the L27 has been voted best although the 88's-91's which I was not previously looking at before sound kinda of good too anybody have any opinions on those
Also how about the Northstars I took a quick look and see these are LD8's or L37's comparing to the 3800's how do these compare even though they have more power do they last as long and Ive heard that the GXP's can be nothing but problems
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
freneticburn
- Year and Trim: 1998 Bonneville SE?
well duhwillwren wrote:everyone here is going to post their own PERSONAL preferences based on what they own/drive.
- BlackHawk99
- Senior Moderator
- Year and Trim: _
I've owned four Bonnevilles so I feel I'm somewhat able to judge...
92 SSEi
93 SE
87 LE (I think it was)
99 SE
Of all the cars I owned, the most problematic was the 92 SSEi. Too many electrical issues and I never had a secure feeling that it wouldn't fail me.
On the other hand.... The 87 LE was an outstanding car. We finally sent her to the bone yard at 261,000 when the fuel pump failed. When trying to drop the tank, the fuel lines snapped. The brake lines were toast too. Otherwise it was a VERY VERY good car. Even the A/C worked in 2003 when she was junked.
Between the 93 SE and the 99 SE, it's a toss up. I absolutely loved each car and put piles of miles on each. We sold each of them off at 175,000 and they were both on the original transmission and shifted fine. I never had to do anything to the L27 except change the oil. However, I did turn wrenches a lot more on the 99 thanks to three UIM and LIM gasket replacements.
But, if I had to do it again... I'd buy another L36 powered one. In an instant. Something about that L36 that I really like (and yes, I like it more than than the L67 in our GS).
92 SSEi
93 SE
99 SE
2012 Ford Fusion SEL, 2012 Chrysler Town & Country, 2007 Chevy Silverado LT, 1999 Pontiac Firehawk, 1979 Pontiac Trans Am
- Sirius
- Year and Trim: 2003 SSEi
All y'all are up in the night. Everyone knows white '93 SSEs used to be the best until they get wrecked. Now, obviously, black 2003 SSEis are.
Everybody knows this.
Screw you, Photobucket.
94SilverSSEi
68 w/400
Anyone have anything to say about the Northstars
Clay
- bill buttermore
- Retired Gearhead
Well gonzo reminded me, so....gonzo4191 wrote:65 bonneville are the best in every category
We owned a car like this when it was seven years old. Ours was black lacquer with red vinyl interior, 389 4bbl. No air, roll down windows, but a beautiful car indeed. What a styling statement.
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
wjcollier07
They're an aluminum block, aluminum head V8 engine that has no aftermarket to speak of. It spins quick and sounds sexy, has a top end that kicks like a horse, but no real low end beef.94SilverSSEi wrote:Anyone have anything to say about the Northstars
They don't wear out too fast, I've seen quite a few very high mileage ones that run perfectly still. It's an excellent GM Premium V8. As far as the transmission goes, the 4T80E is one of the best transverse transaxles GM has ever made in my opinion. Its pure BEEF. With proper maintenance of a Cadillac NorthStar drivetrain, other than sensors and the other normal crap that can fail, the actual engines are excellent. But I like them because I'm not really into modding too much...I like it, but I'm really take it or leave it.
John
