What did you do to your car today?
Re: What did you do to your car today?
No screws for the caps. Just pinch their "legs" and wiggle and pull.
94SilverSSEi
Year and Trim: 97.2 40th SLE
68 w/400
94 SSEi
Post by 94SilverSSEi »
So does sheering off a camber bolt, snapping the head off a brake hose bolt, dropping the bolts in the oil pan and spilling brake fluid all over everywhere count? Just called it quits after all that before more things got broke.....
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
I mean technically, you did DO those things to the car. So it does count. :P
1oldman
Post by 1oldman »
94SilverSSEi wrote:So does sheering off a camber bolt, snapping the head off a brake hose bolt, dropping the bolts in the oil pan and spilling brake fluid all over everywhere count? Just called it quits after all that before more things got broke.....
Clay, welcome to my world. No feeling sorry for yourself. Step back (even if you have to for a few days, or week), take a deep breath, get a game plan together, review it to see if you've considered all the caveats you can think of, then go at it again. There's nothing wrong with getting someone to come over and give a second opinion either. And yes,unfortunately, it does count. But I do stuff like that when I work on the car too. - BC
spoiledred94
Post by spoiledred94 »
Probably not surprising but I broke the head off the oil level sensor putting on the oil pan because I thought it would be easy to just wiggle the assembly together so I left the sensor in place.
Not a good choice. Id reiterate what was said. When things start going bad put down the wrench and relax.
great car. Wrecked
Burnt Bonny.
thesam1984
Year and Trim: 1996 Buick Lesabre Custom - metallic dark cherry
Post by thesam1984 »
myfirstbonnie wrote:Yesterday I put air in Chicken Guts' tires. Also working on the garage to get both vehicles in it......... at the same time.
I'm also working to get enough space to get one car into the garage. I know I can do it because I used to put my full size pickup in the garage (the garage door would only close if ol gertie was in nose first)
However im getting something quite radical thats going in there...
Check out my "Black Betty" in the other rides for this
http://www.pontiacbonnevilleclub.com/fo ... 45554.html
As for my car, I tidied up the white walls... I have had the worst time making the paint stick, never before did I have such problems... I may have to go back to the "white letter tires" on the other side.
Today I drove almost 100 miles back and forth around the city doing things for PetBull project
Roads... Where we're going, we don't need roads
spoiledred94
White plastic acrylic paint sticks and lasts great.
great car. Wrecked
Burnt Bonny.
monte0
Year and Trim: 1999 Bonneville SSE
Post by monte0 »
Changed trans and mounter mount. I'd say the trans mount was toast...
1999 Bonneville SSE-79k
1970 Monte Carlo SS-waiting for new motor/trans best 12.5 at 109
2001 Regal GS-modded
1999 Olds 88-22,000 original miles
2004 Impala SS
1997 Regal GS-best 13.9 at 98.2
1999 Regal GS
2000 Regal GS
1997 Regal GS
monte0
Post by monte0 »
Also tuned my SSE....power definitely picked up
2004 Impala SS
1999 Regal GS
2000 Regal GS
1997 Regal GS
haro1225
Year and Trim: 2004 GTO
Post by haro1225 »
I fixed the stupid whistling noise on the 04 and then I took care of a couple small issues on the 96. Changed the air filter and tightened up a leaky heater hose clamp.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
94SilverSSEi
68 w/400
94 SSEi
Well after lubing that camber bolt for a week and beating on it relentlessly, looks like it might be time for the torch and a new control arm.
But in other news I did get a trans put in and everything went perfectly smoothly, and functions properly. I'm waiting for the other shoe to drop..... Something fishy there, nothing ever goes that smoothly. :P
monte0 wrote:Changed trans and mounter mount. I'd say the trans mount was toast...
Yeah, I'd say it was time for a new mount. That thing has seen its day.
Clay
bs009
Year and Trim: 82 GP
Post by bs009 »
Changed the oil on the Regal and fixed the squeaking exhaust that it had for a while. Also made some progress on the GP over the weekend.
MattStrike
Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
'92 Trofeo
Post by MattStrike »
I looked at the SSEi, then Ben took the battery tender off it. Battery is toast, wasn't able to start it after charging all week.
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
monte0
Post by monte0 »
Cleaned the car up more, de-pinstripped the body...that was fun.
2004 Impala SS
1999 Regal GS
2000 Regal GS
1997 Regal GS
1oldman
Post by 1oldman »
Today, took the car to the car wash, used a "new mico-something-or-other wax" and, vacuumed it out. Yesterday put on new front rotors and pads. Took me from noon to 9:30PM. The wife had to call the youngest son to come help me bleed the brakes. I didn't have enough energy to finish. Needless to say, he wasn't happy with me putting the brakes on myself. He told me not to try it with the rear brakes as I have them in the box waiting to be installed.
http://www.pontiacbonnevilleclub.com/fo ... ml#p438648
- BC
96 SSEi
Post by 96 SSEi »
charged my battery-- it is original delco
2000 SSEi
past rides:
1996 SSEi
1992 GTP
1987 Grand Am
pauller
Year and Trim: 04 Bonneville
Post by pauller »
Changed the oil and flushed the brake fluid.
monte0
Post by monte0 »
Pulled carpet out to diagnose water leak, put reman air pump in, replaced rear air shocks(bye bye CCR), put new fuel pump in, changed oil, tuned again, new sun visors, etc and did a little junk yard scavenging to find some parts. All since Friday morning.....
2004 Impala SS
1999 Regal GS
2000 Regal GS
1997 Regal GS
1oldman
Post by 1oldman »
monte0 wrote:Pulled carpet out to diagnose water leak, put reman air pump in, replaced rear air shocks(bye bye CCR), put new fuel pump in, changed oil, tuned again, new sun visors, etc and did a little junk yard scavenging to find some parts. All since Friday morning.....
You are one busy Bonneville owner! - BC
monte0
Post by monte0 »
I'm that way with all my cars, lol. Catching up on stuff people neglected
2004 Impala SS
1999 Regal GS
2000 Regal GS
1997 Regal GS
