Control arm questions
- J Wikoff
- Year and Trim: 1992 SSE
Re: Control arm questions
At this point, I have a small pile of shiny yellow zinc plated nuts.
- MattStrike
- Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
I've re-used spindle nuts before. Unless I'm missing something here the H-body does not use a self-staking nut.
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
Zeik75
- Posts like an L36
- Year and Trim: 1988 LE
2000 SSEi - Location: Lincoln, NE
Now that i think about it though they are oblong on the one end. I have thought of them as a lock nut in the past, and i did notice that the last time I put them on one nut threads on a couple spins then must be ratcheted, the next threaded on all the way with fingers then was just torqued.
-Austin-
MKMike
- Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
In JWikoff's defense, the service manual does instruct you to use new spindle nuts when you replace the front hub, but I have never seen this done at any repair shop.MattStrike wrote:I've re-used spindle nuts before. Unless I'm missing something here the H-body does not use a self-staking nut.
Whether or not this is a statement to absolve the manufacturer of any legal responsibility, rather than one based on an actual need is beyond the scope of my knowledge.
- J Wikoff
I finally got around to this, and of course I have a problem. The bushing removal tool adapter doesn't appear to fit over the flared/lipped end of the bushing. Even if it did have a large enough adapter, the threaded shaft has to point forward where the shape of the subframe gets in the way. So..... poop. From the wear marks on the subframe, it looks like for forward end of the control arm has been contacting it. So this bushing might in fact be my shimmy problem.
HOW DO I GET IT OUT??
- KM AXer
- GXP Member
- Year and Trim: 1993 SSE Medium Garnet Red Metallic, Gray
Wrenching can be difficult sometimes...
If you can't figure a way to set up the tool to press or pull it out, then the options are:
Cut it out (think sawzall)
Burn it out (torchify)
Drill it out (holes in the rubber until Swiss cheese)
Chisel it out (air chisel preferred)
Or, any combination of the above options, plus probably plenty I have not mentioned.
Once the mount is empty, have you thought about how the new one is to be put in? Yes, yes, one thing at a time....
Alan Sheidler
Proud Third Caretaker of the Family Heirloom '93 SSE
Medium Garnet Red Metallic, Gray Leather Interior
Silver Cross-Lace Wheels (I love this car)
- J Wikoff
I think I can use the tool to press it back in. But not out.
BTW, I had virtually no issue getting the bolts out. It took a little pb blaster and oomph, but wasn't too bad. They slipped right out once the nut was off.
- J Wikoff
95naSTA loaned me his tool specific to this job and I got er done. I couldn't test drive it yet, so I don't know if my shimmy is still there.
If I ever met the engineer responsible for pressing the bushing into the subframe, I'd want to junk-punch him.
