cable for cp9110 edit: made the cable now some questions
tpulliam79
Year and Trim: 1991 SSE+I. 1994 ssei
Post by tpulliam79 »
So my 94 ssei obviously has the weird OBD 1.5 system I ordered a scanner that will work but need to find someone that can make the cord that I need. I have tried to contact Slug and I know he used to make them but have gotten no response. Does anyone know where I can find one? :dontknow:
1991 SSE+I ( supercharged)
1994 ssei
WCBF '08
SuperHbody
Year and Trim: 1988 LE
Re: cable for action cp9145
Post by SuperHbody »
Try aldlcable.com, they have specially made cables for 12 pin OBD 1 and 16 pin OBD 1.
tpulliam79
Re: cable for action cp9110
okay so my 9110 scanner is here but I need to know which cable I need to buy so I can try to modify it to work. I also have the actRon 9145 scanner which works for everything except kr from what I can tell. I don't want to destroy the cable I have for the 9 145 so I need to know if anyone has an old Cable they don't use anymore or which part number I am looking for when ordering the cable. Thanks for the help here just trying to get her dialed in
1994 ssei
WCBF '08
tpulliam79
Re: cable for cp9110 edit: made the cable now some question
So i think i rewired the cable correctly, I am able to read and record data but is still showing 0 kr just as my 9145 scanner did. took on a few wot runs still 0 kr? if the scanner is working then it must be wired correctly right? the engine itself has less than 30000 miles on it and car has 130 is it possible to just be kr free at all times or should i see a little from time to time? I want to pulley down but need to be sure the kr readings are correct. are there certain conditions that may make it appear?
1994 ssei
WCBF '08
RJolly87
1994 Buick Regal Custom
Post by RJolly87 »
I wonder if you can induce false knock just to ease your concerns? Tapping the block with something metal while running comes to mind.
~Randall~
RJolly87
Post by RJolly87 »
I would also confirm the knock sensors are actually reading knock too.
~Randall~
