Shallow aftermarket receiver?
IanRosean
Year and Trim: 2000 Pontiac Bonneville SE
Post by IanRosean »
Does anyone know of a shallow CD-less media head unit that is like am fm USB Aux and possibly blue tooth, that the depth is like super shallow like around 4 inches deep so I do not have to cut the plastic that is behind the stock radio? Any input is greatly appreciated, I am terrified of attempting to cut that plastic and something going wrong.
bobgto65
2004 Bonneville GXP
Re: Shallow aftermarket receiver?
Post by bobgto65 »
I have not seen one. But cutting out the back of the dash is not too hard to do. And it will not prevent you from reinstalling the factory radio later on.
bobgto65
burger
Year and Trim: 1997 Pontiac Bonneville se
Post by burger »
Also you can get an a dash install kit that sticks out like an inch so you dont have to cut anything. At least it is that way for the older models.
97 Bonneville se-Winter car
85 Yamaha xj700-Summer cruiser
IanRosean
Post by IanRosean »
I have the 2000 bonneville SE. What kind of tools do you use to cut it? I tried manipulating the right on cable and it seems to be like right on that plastic back there so I'm super nervous. But like I said I don't need a cd player and would prefer a touchscreen with a shallow depth so I don't have to cut anything
bobgto65
2004 Bonneville GXP
Post by bobgto65 »
just use a drill with a 1/2 inch bit and drill holes around the back next to each other until you cut out the whole back. A dremel tool may also work.
bobgto65
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Post by repinS »
I used a hacksaw blade.
gweg_b
Year and Trim: 95 LeSabre Custom
01 Bonneville SSEi
09 G8 GT
Post by gweg_b »
I had a friend help me. I removed the vent next to the radio and stuck my hand back there to hold the ribbon cable while he used a Dremel (yes, we were being careful with my hand, too). Took probably 5 minutes to complete.
I later went back in there with that Dremel to open up more space on the right side for hiding cables.
- Greg | -- Project Prasinos -- |
1995 LeSabre Custom: 312K Miles | Custom K&N CAI | Edelbrock SDT Muffler | Camaro Tips | 180 T-stat | LED Interior
& Exterior | 20% Tint | PA Grill & Portholes | Limited Trim | GTP Rims | Ported LIM | Plus Many More Mods | Restoration Thread
2001 Bonneville SSEi: 225K Miles | Instense FWI | Intense MPS (3.4") | 180 T-stat | ZZP Plog | Ported Rear Manifold |
ZZP 3" Downpipe | Magnaflow Cat | Retrofitted HIDs | GenV M90 | GXP Brake Upgrade | 35% Tint | Plus Many More Mods |
2005 Bonneville GXP: 101K Miles | Custom FWI
2009 G8 GT: 89K Miles | 35% Tint | Roto-Fab CAI | SOLO Mach Exhaust | BMR Tunnel Brace | BMR Sub Frames | BMR STB |
Kooks Headers | QTP Electric Cutouts | BMR Sway Bars | Elite Engineering Catch Can | Innovative Dual Wideband Kit
1984 Caprice Classic Wagon: 86K Miles | Restoration Project
IanRosean
Post by IanRosean »
I purchased the gmrc 04 and I just ordered a mechless head unit that is only 3 and 5/8th inches deep so problem solved lol
Thanks for all the input though guys
DaMaroon
Year and Trim: 2003 SE
Post by DaMaroon »
Did it have a screen/ touchscreen? If so what is it?
IanRosean
Post by IanRosean »
No it didnt have a touchscreen it was a cheap Boss 614UA for $19 bucks on walmart.com, its all I need though because it pushes 50w to each speaker and i'm just gonna plug in my phone to it.
the only touchscreen I know of that will fit in our bonnies is the parrot asteroid which is like $499, im good on that hahaha
