My wife asked, "How long will this take?"BillBoost37 wrote:Adam..if it takes you 24 minutes....you are doing something wrong.
"1/2 hour or so.
It took over 3 hours.
I rented a puller from Canadian Tire. Great, good to go, right?
Disconnected the battery, safety first! Then removed the SIR/horn assembly by removing the four Torx screws on the back of the wheel. Here we see the main nut that must be undone.
Following the instructions of the puller, I put it in place and began removing the wheel. Here is where the comedy comes in: The puller managed to mangle the threads for the main nut that holds the wheel on. Completely mushroomed the top of the threads, unbenounced to me. Here is the moral: DON'T TAKE THE NUT ALL THE WAY OFF. Just loosen it, so the puller can crack the wheel away from the splines. Remove the nut AFTERWARDS! Most of you probably know that, but not I.
I could not get the nut back on for the life of me. My wife comes out, "Done yet?" Oh yeah, I finished it off alright...
I need a die to re-thread. How am I going to get to Canadian Tire? My neighbour! He came through and took me. The thread pitch seems to be 1/2" N.F. so I grabbed the die and headed home. I treid to re-thread, panick stricken at this point. Finally, I managed to clean them up enough to get the nut back on. Whew! I'm a bonehead, at least I'm a resourceful bonehead though when things go wrong.
I returned the puller when I picked up the die:
Cdn Tire Guy: So, how did it work out for you?
Me: Not so well.
Why?
I explained.
You know, I've rented this tool out 100 times, and never heard of that happening.
Me: Leave it to Beaver.
Wanna see how it turned out??
Before: Old Philthy Mc Crusty was a nasty wheel. You'd get leather/skin particles on you after driving, as the leather had worn so badly:
It's funny. Your steering wheel is how you are in touch with your car. When your sense of touch finds nastiness, hand leavings and grotiness, it tends to affect your pleasure to drive. It's not fare to have a car that you love so much, when it feels icky to drive.
New Hotness, and good feelings:
Right after putting my tools away, I took the family to a local outside festival. It now has that AAh! feeling when you drive. Huge difference.
So remember, when pulling a steering wheel, leave the nut on until it is free from the splines, then take it off!
This job should have taken 20 minutes...
Cheers,
Adam
