Additive to reduce E85 damage?
ricosuave420
- GXP Member
- Year and Trim: 1993 ssei supercharged bright white
Hi all, I had a guy in a 76 or 78 cadillac devile or something and he kept his car like super duper clean, he was talking about some kind of additive that u put in the tank everytime you fill up, he said it was like a cap full per tank that stops the E85 from eating away at the fuel lines and fuel seals, basically it negates all damage done by E85 to older cars but for the life of me I can't remember what it was called, I went to a napa store and explained what I was looking for and he gave me seafoam which goes in the tank but it said you have to add the whole bottle per tank so I knew that wasn't what I was looking for, can anyone help?
1993 SSEI SUPERCHARGED AKA "ANGLE"
180,000 MILES
2000 WATT SYSTEM, ALPINE 7 INCH FLIP OUT TOUCH SCREEN TV, 2 12" SUB WOOFERS IN THE TRUNK
2000 WATT ALPINE AMP
LADIES CALL IT A ROLLING CLUB, I GUESS THE VIBRATIONS GET THEM READY FOR SOME FUN
SSEI= SSEXI
NOW WITH BEAUTIFUL BLUE NEON UNDERGLOW
CERTIFIED EAGLE SCOUT MAY 19 2009
REFERRED TO BY EVERYONE AS JAMES BONDS WEEKEND CAR, REFERRED TO BY ME AS ANGEL
180,000 MILES
SSEI= SSEXI
- xxdabroxx
- GXP Member
- Year and Trim: 2001 Bonneville SSEI 32,000 miles bone stock
Re: Additive to reduce E85 damage?
Don't run E85 in vehicles not designed for it. They will run lean. Lean is bad.
First of all, it's not E85. The fuel you put in your tank is E10, 10% Ethanol, 90% Gasoline. E85 is a different blend of Ethanol, and you have to have a vehicle designed for it, or it will do even more damage than what you think E10 is doing...
I think this is what you're looking for: http://www.amazon.com/STA-BIL-22264-CS- ... roduct_top
Not sure how much it helps, there's only so much an additive can do. If you're that worried, the best thing to do is find a gas station that sells non-oxygenated gasoline (oxygenated = ethanol).
ricosuave420
- GXP Member
Well that certainly explains why I failed emissions and had to get someone to fudge the numbers so I would pass
180,000 MILES
SSEI= SSEXI
180,000 MILES
SSEI= SSEXI
ricosuave420
- GXP Member
Now I only run shell premium, do you guys know if all shell has the ethonal in it or does it vary from station to station?
180,000 MILES
SSEI= SSEXI
180,000 MILES
SSEI= SSEXI
ricosuave420
- GXP Member
Aaa yes that is what I was looking for, thank you beast
180,000 MILES
SSEI= SSEXI
180,000 MILES
SSEI= SSEXI
- nos4blood70
It should say on the pump if there is ethanol in the fuel. Depending on where you live it may be hard to find non-ethanol fuel. Like in Illinois.
ricosuave420
- GXP Member
I'm in nj and I asked my boss and he said unless it's stated on the station that it sells e85 all stations run the 10% ethonol
180,000 MILES
SSEI= SSEXI
180,000 MILES
SSEI= SSEXI
It's a federal mandate, all gasoline in all states, unless otherwise noted, is 10% Ethanol. There is a exemption for deoxygenated fuel for collector cars, snowmobiles, small engines, etc, but you pay for it..
ricosuave420
- GXP Member
Great, just fantastic, on a youtube video by motortrend the guys left a racing truck sit for 2 years with a carb with that ethonal gas and they came back and the carb was caked in this green crap and spent a whole day rebuilding it
180,000 MILES
SSEI= SSEXI
180,000 MILES
SSEI= SSEXI
Merrillspontiac
- Year and Trim: 2000 Pontiac Bonneville SE
Why would a 93 be going for emissions test anyway?
1997 Oldsmobile Eighty Eight LS
1993 Buick Regal GS Coupe
1992 Buick Regal Limited Coupe
- nos4blood70
Your car is dealing with the E10 just fine. I wouldn't freak out about it.
DaMaroon
- SSEi Member
- Year and Trim: 2003 SE
That happens with gas with no alcohol as well. Even stabilized fuel would likely have problems after that much time.ricosuave420 wrote:Great, just fantastic, on a youtube video by motortrend the guys left a racing truck sit for 2 years with a carb with that ethonal gas and they came back and the carb was caked in this green crap and spent a whole day rebuilding it
On the inside that is. If it was on the outside it had other problems.
deano55
- Posts like an L36
E85 is available out here in our area. We had a Taurus that ran on that stuff, a loss of 3-4 mpg. Not worth the lesser price, might be good in the winter to get the moisture out once in a while. Normal piston rings are not for E85 I've heard.
deano55
- Posts like an L36
Take a look at this E85 video http://www.google.com/url?sa=t&source=w ... A1_VNEgWow
deano55
- Posts like an L36
Our recent trip to upper Wisconsin showed us many of gas stations did not have ethanol in there mix, thus lower octane (91)ricosuave420 wrote:Now I only run shell premium, do you guys know if all shell has the ethonal in it or does it vary from station to station?
DaMaroon
- SSEi Member
deano55 wrote:Take a look at this E85 video http://www.google.com/url?sa=t&source=w ... A1_VNEgWow
Seems like an infomercial. I'm in favor of the use of ethanol and live in a town with an ethanol plant but one vehicle is not statistically significant. Didn't read the text.
deano55
- Posts like an L36
Yes, look at the heading
