00+ fuel pump upgrade.
- Oldsman105
- Posts like a Northstar
- Year and Trim: 2001 Bonneville SSEi
My fuel level sensor is going haywire . SO since I have to pull the sending unit I might was well upgrade the fuel pump. I wanted to see what others had done to do upgrades . I remember reading some compatibility issues with the upgraded pumps. Any and all help is appreciated.
2003 SSEi
- Year and Trim: 2003 SSEi.
LOTS of Mods
Re: 00+ fuel pump upgrade.
do you have the venturi setup already or no??
Racetronix has a upgraded pump (modified walbro iirc). I believe the 00 bonnies have a Ventri pump like the GTP's.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
- Oldsman105
2003 SSEi wrote:do you have the venturi setup already or no??
No I haven't bought any components yet. I recall you saying that the venturi setup or maybe it was the bottom of the sending unit that is different from the GTPs and that the normal high flow pumps have issues with our car.
- bobtaz13
- Posts like an LG3
- Year and Trim: 2001 SSEi
1991 SE - Location: Minnesota
I've got this Walbro 255lph Fuel Pump installed on my 01.
http://intense-racing.com/Merchant2/mer ... =3800_Fuel
It was easy to install and works great.
2001 SSEi | Galaxy Silver | GenV supercharger P&P | Intense 3.2 MPS | Intense FWI 4"| Custom PCM | TOG Ceramic headers | Magnaflow 3" cat | 180° stat | Aeroforce scan gauge | PRJ plug wires | PRJ fuel rails | Silicone vacuum lines| AP103 plugs | 3.2 MPS | 42.5# injectors | Intense 1x cam kit | YT 1.8 Rockers | 105# springs | Meziere HD pump | N* Tb | 185mm MAF | 2" Phenolic Intercooler | Oil pressure kit | L32 short block | 5% overdrive SFI Balancer | L67 heads custom ported | EBC USR Rotors | EBC Red stuff pads | Custom HID Fog lights, with HI-beam over ride | Polyurethane motor mount | Energy Suspension end links | GXP Shocks/Struts | Custom Drop springs Front, Rear FE5 Springs | GXP Strut tower Brace | GP GXP 18x8 Rims | Polished Exhaust tips | Triple Edge High Performance Street/Strip 4T65E-HD |
- Larz01
- SSEi Member
- Year and Trim: 2K1 GTP
If you put in an aftermarket pump, doesn't really matter if it has venturi or non, just dont drive around untill the gas light comes on. Venturi systems have a difficult time keeping up in our canisters, and most fuel pump manufacturers dont want to deal with them. So its your decision if you like running the tank low or not.
Just Your Average open loop tuned Ethanol Driven DD's
2k1 GTP: 13.307 @ 104: Headers, 1.9's, Tune
2k12 Impala: Stock
2k12 Impala: Stock
- Oldsman105
I like to run my tank low.
bobtaz13 can you run you tank down to the warning light and not have it stall?
- bobtaz13
- Posts like an LG3
I believe I had about 1/4 tank in mine when I did it. I would also replace you fuel level sender while your in there. http://www.pontiacbonnevilleclub.com/fo ... f=9&t=3463
